FC 0.17/Qt5 compatible NaviCube
nyholku
Post by nyholku »
Hi everyone,
I've updated my experimental NaviCube to FC 0.17 code base and refactored it to be compatible with Qt5.
You can find the code here:
https://github.com/nyholku/FreeCAD/tree/navicube-qt5
Screenshot below.
wbr Kusti
Screen Shot 2017-11-18 at 13.10.53.png (246.03 KiB) Viewed 4436 times
Jee-Bee
Re: FC 0.17/Qt5 compatible NaviCube
Post by Jee-Bee »
Nice work!!
triplus
Post by triplus »
It works when compiled on Ubuntu 16.04 (Qt 5).
P.S. Has the size changed and it is a bit bigger?
Will this be part of 0.17 release ?
If not we should track it via the bugtracker as well.
nyholku
Post by nyholku »
Yes, it is a bit bigger, I felt it now optimal for me, but this is not final. Might be configurable. We'll see.
regis
Post by regis »
nyholku wrote: Sat Nov 18, 2017 11:12 am Hi everyone,
Screenshot below.
wbr Kusti
Amazing, but I see a bunch of new icons, that i don't see often, what are those?
pablogil
Post by pablogil »
I have the feeling it has been asked before but: could Navicube be ported to an “easy to install” addon?
It’s so cool that I feel it should go into master or shared as an addon...
Thanks
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Dacicusan
Post by Dacicusan »
Very nice interface. This will make FreeCAD more usable.
The icons are also nice. They are available for download? Maybe a new icon theme using this icons will make the interface more pleasant to work with.
looo
Post by looo »
It's a nice add-on but last time I tried it, it slowed down the scene quite a bit. I don't know how it is implemented, but it feels like a qt-widget overlay?
nyholku
Post by nyholku »
Slowed down?
Hmm, interesting, did not notice that.
It is not a qwidget it simply taps to the opengl render/redraw call on (on View3DInventorViewer) and renders to the OpenGL context (just like the standard XYZ axise orientation indicator) so I would not expect drawing twenty odd more polygons make any difference.
Hmm...perhaps it is the cursor tracking that takes time as this draws offscreen (but then again that is just the same few polygons).
I may have to investigate this further.
wbr Kusti
PS Those new icons are from here:
https://github.com/pgilfernandez/FreeCA ... eme_simple
