default program font size
Re: default program font size
There is no parameter in the settings where font size can be changed. But with a little Python hacking you can try this:
from PySide import QtGui
f=QtGui.QApplication.font()
f.pointSize() # returns e.g. 8
f.setPointSize(10)
f=QtGui.QApplication.setFont(f)
sgrogan
Post by sgrogan »
@wmeyer You've addded 20 years to my career :D
"fight the good fight"
BCBaldwin
Post by BCBaldwin »
I am having the same issue. Just downloaded the program and reading the initial documentation and going through the individual steps to learn the program and the font is really small. I have tried to make adjustments in the preferences and also on windows. It increases the sizes of everything else but the documentation. I have provided screenshots for comparison. I can understand why OP decided to not use the software if this simple detail has been neglected. It makes it really hard to read.
I have 20/20 vision btw
I would add an image but I cannot figure out how to do that either. lol If someone wants to tell me the steps to add a few screenshots to this post I will do that as well.
Thanks in advance!
OS: Windows 10
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Hash: da2d364457257a7a8c6fb2137cea12c45becd71a
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
bejant
Post by bejant »
Hi BCBaldwin. and welcome!
BCBaldwin wrote: Thu Aug 17, 2017 5:00 am Just downloaded the program and reading the initial documentation and going through the individual steps to learn the program and the font is really small. I have tried to make adjustments in the preferences and also on windows. It increases the sizes of everything else but the documentation.
If you downloaded the 0.16 FreeCAD Manual in .pdf format I think you would "zoom in" instead of using changing the text size. I use the + key to zoom in, although in the Edit > Zoom pull-down menu of my document viewer it says to use the Ctrl and + keys together (I'm using Linux instead of Windows). There should also be a GUI only method in your document viewer but I don't know what that might be as I'm now not using Windows.
If you are referring to the FreeCAD pull-down menu Help > User Documentation item, that opens in your web browser and so you would zoom in just as you would do with any other web page (for me this keyboard shortcut is done by pressing the Crtl and + keys).
BCBaldwin wrote: Thu Aug 17, 2017 5:00 am I would add an image but I cannot figure out how to do that either. lol If someone wants to tell me the steps to add a few screenshots to this post I will do that as well.
A screen grab would help us see what you're facing. Item 5 in the first post here gives info and a link on how to use the Snipping Tool in Windows:
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
To attach an image to your post:
After you have saved your image, as you are typing your forum reply and want to add an image, click on the Attachments button which is below the window where you type your message:
Next, click on the Add Files button:
navigate to wherever your image is located, select it, and click the Ok (or Open) button (or press the Enter key). After the file appears under the Add Files button, you can click the Place Inline button:
to place it at a specific location inside your reply (which is what I did here), otherwise it will appear in your post after the text portion.
blue and strike-through = edit
giddyup
Post by giddyup »
wmayer wrote: Wed Feb 11, 2015 9:19 am There is no parameter in the settings where font size can be changed. But with a little Python hacking you can try this:
f.setPointSize(10)
I have a high rez monitor and the above helped me greatly.
Is there any way to save these somewhere so that it does this every time I open the software by default. I have attached a before and after image.
The very easiest would be to create your own FreeCAD module. If you have write access to your FreeCAD installation then go to Mod and create a sub-directory e.g. HighRezMonitor. If you don't have write permission go to %APPDATA%\FreeCAD\Mod and create the directory there.
Inside HighRezMonitor create the file InitGui.py and copy the above code snippet into it.
pl7i92LCNC
Post by pl7i92LCNC »
is this somwhere mentioned on Wikipedia to get this better published
as im using this for education on a near 10meter beamerprojektion i woudt have known this in 2015+
Simbioz
Post by Simbioz »
The provided python script works partially on 0.19, menu fonts are affected but combo view fonts are not.
OS: Arch Linux (sway/sway)
Version: 0.19.24415 (Git)
Branch: makepkg
Python version: 3.10.5
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.5.3
Non native English speaker.
Bance
Post by Bance »
FC 0.19 is not the current release version. Try in 0.20 or dev.
Bance wrote: Sun Jun 26, 2022 7:24 am FC 0.19 is not the current release version. Try in 0.20 or dev.
Yes this is true, but the code snippets from @wmayer is from 2019, so I suppose it will work on 0.19 too.
To try to answer:
Not every fonts are controlled by the code above, some part of FC have some "font size" specified in other ways.
Being a Qt applications, there are many ways of specifying "font size" even in "each widget" definition or using "stylesheets" so sadly there is not a "unique set to tune".
Something could respond to settings made in the "Editor" Tab under Preferences >> General that although controlling explicitly only the Editor fonts it seems to control even the "Python Console" and "Report View" windows font size.
Probably making some "Feature Request" could help at least for the main FC, Addons and other WB could or not could be affected, depending if they try to guess the actual FC font size value and replicate it on the added "Qt Widgets", or if they reuse to interact with the user standard "FC Widgets".
I know that there is some confusion, but the whole mechanics behind FC Gui is difficult to guess as there is no (hoping "not yet") a "complete documentation" on modifying or interacting with Gui parts of FC.
Any informations or findings will be appreciated.
Hope it help.
