Unusable Helix Projections
ulrich1a
Re: Unusable Helix Projections
Post by ulrich1a »
shoogen wrote: ulrich1a wrote:Your picture from the last post is a Draft-Projection or a Drawing-Projection?
Drawing
So there is a solution for the disturbed curves. Glad to here!
I compared a Drawing projection from
OS: Debian GNU/Linux 8.0 (jessie)
Word size: 64-bit
Version: 0.15.3779 (Git)
Hash: 4b8f262157ad843897cca695d0492fd281eb41bd
Python version: 2.7.7
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
with
OS: Windows XP (Wine)
Word size: 32-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
The projection with OCC 6.5.1 has not the much visible hidden lines, where as the projection with OCC6.7.1 looks like yours except that it has also the disturbed lines.
Was there a change in the api for the projection function between those OCC releases?
Ulrich
shoogen
Post by shoogen »
ulrich1a wrote:The projection with OCC 6.5.1 has not the much visible hidden lines, where as the projection with OCC6.7.1 looks like yours except that it has also the disturbed lines.
I don't think so. But surely there are now lines visible which should not be there. In my understanding the visible outline should not contain intersecting edges. I reported this as http://tracker.dev.opencascade.org/view.php?id=25776
Drawing
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.1
with
Word size: 32-bit
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Ulrich
Ulrich, can you see if issues are still reproducible with OCC7.1 ? (even though @shoogen's upstream ticket hasn't seen any progress)
NormandC
Post by NormandC »
With OCC 6.8.0, marginal improvement:
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
More improvement in OCC 7.1.0 / Drawing wb, still not perfect
Actual regression in OCC 7.1.0 / TechDraw workbench :?
Version: 0.17.10611 (Git)
Build type: None
Hash: 44a9ecd25f27ec3efe52c9de9c95ef2b3e19dd17
Qt version: 4.8.7
OCC version: 7.1.0
Thanks NormandC, I've notated issue #1937. Is there anyone that can bump the upstream ticket shoogen created?
NormandC
Post by NormandC »
What's really odd is that I don't get as nearly garbled projections with a newly built swept helix, compared to ulrich1a's original model.
See https://forum.freecadweb.org/viewtopic. ... 59#p167159
wandererfan wrote:ping
FYI you were mentioned in https://freecadweb.org/tracker/view.php?id=1937#c8706
wandererfan
Post by wandererfan »
ulrich1a wrote: Wed Jan 28, 2015 10:06 am The top projection is only a simple line instead of the expected ring. The lower projection has not all hidden lines correctly removed.
Should be improved by git commit 052704eb.
Still an issue with the ID of the top view, I think.
