Crash when doing sweep
wvmarle
Post by wvmarle »
Parts toolbox, select Sweep tool
Add Wire, Wire001, Wire002 for the sweep
Select the ellipse for sweep path
Create the sweep: crash
Probably I'm doing something illegal here by having the ellipse extend beyond the Wire and Wire002, but nevertheless it shouldn't crash.
Submitted bug report: issue #1926
sweep crash.fcstd
(5.88 KiB) Downloaded 64 times
Reason: BBCode tag [bug] added
cox
Re: Crash when doing sweep
Post by cox »
Edit Crashes for me aswell
EDIT- When sweeping along the full, 360° ellipse no problem. The crash happens when sweeping along the ellipse arc from -5° to 185°.
Sorry for any confusion
No crash here
OS: "Arch Linux"
Version: 0.15.4495 (Git)
Hash: 1f44226882071790a86a16f86bfacda0e7a5a880
Python version: 2.7.9
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.7.1
Need help? Feel free to ask, but please read the guidelines first
wvmarle
Post by wvmarle »
When sweeping along the full, 360° ellipse no problem. The crash happens when sweeping along the ellipse arc from -5° to 185°. The wires are at 0° and 180° along the path; when the ellipse runs from 0° to 180° it also goes fine.
sgrogan
Post by sgrogan »
I get an error but no crash
OS: Windows 7
Version: 0.15.4497 (Git)
Hash: 8fbe631046142e1cb9ab3f1d14258ccecff7a21b
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
"fight the good fight"
shoogen
Post by shoogen »
sgrogan wrote:I get an error but no crash
That is just some platform dependent behavior. When windows (or in this case FreeCAD tells you about an "Access Violation" the program crashed. Even if compiler flags prevented it from being killed. Please use the severity "crash" inside the bug tracker for those errors.
sgrogan
Post by sgrogan »
That is just some platform dependent behavior. When windows tell you "Access Violation" the program crashed. Even if compiler flags prevented it from being killed. Please use the severity "crash" inside the bug tracker for those errors.
Understood. Thank you for the explanation.
