[FIXED] Problems with Drawing WB?
quick61
Post by quick61 »
OS: Kubuntu 14.04.1 LTS
Version: 0.15.4454 (Git)
Hash: 0a31bebaedf82a376833ef6e0ddcbdb6638a2acf
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17-dev
Drawing
Some views are not being projected for Cylindrical Part.
Steps - Open Drawing Workbench and select template. Select a Cylindrical Part and pick Insert orthographic projection - No projection is produced. After checking ALL boxes, only a few projections are shown, the rest show an error with no message. (see screenshot)
WormWheel.fcstd
(62.42 KiB) Downloaded 34 times
Mark
This post made with 0.0% Micro$oft products - GOT LINUX?
NormandC
Re: Problems with Drawing WB?
Post by NormandC »
There have been quite a series of topics related to drawing view issues.
I can only find these two for now, but there were a few others:
viewtopic.php?f=3&t=9222
viewtopic.php?f=3&t=8954#p73132 (see top view in the middle)
Honestly the Drawing wb code for projecting views definitely needs an overhaul...
NormandC
Post by NormandC »
I have modeled your part with a single PartDesign Revolution of a sketch. Same problem, a front/side/rear view won't show.
Edit: Draft Shape2DView works, but it adds small line segments aligned with the inner hole, but not on the full height of the part. Strange.
Edit 2: here's my FreeCAD info:
OS: Ubuntu 14.04.1 LTS
Qt version: 4.8.6
OCC version: 6.7.1
WormWheel_normandc1.fcstd
(34.98 KiB) Downloaded 30 times
Reason: Added FreeCAD info.
NormandC
Post by NormandC »
I just found that this is a specific issue with current master.
In v0.14.3705, it works (almost) fine.
(Edit: saving the document from 0.14.3705, then opening in 0.15.4454 and doing a force recompute makes the front and side views fail)
Word size: 64-bit
Version: 0.14.3705 (Git)
Branch: FreeCAD-0-14
Hash: f25e6e4716fb63ef3ac618ce9e552761bbc1b4b1
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
quick61
Post by quick61 »
Thanks Norm, that is just what I am seeing here. 99.999% sure this just happened, as I did a Drawing a couple-3 days ago of a similar part, (just the center section) and it was working fine. That same part fails today in the same manner as this current part. I'll file a ticket on Mantas.
Mark
NormandC
Post by NormandC »
Once you file a new ticket, maybe we could reopen issue #1898 and link it to it.
This commit may be the culprit: git commit 0a31beb
quick61
Post by quick61 »
OK, here is the ticket - issue #1912
Mark
NormandC
Post by NormandC »
Wow, didn't even notice that a plain old cylinder is affected. I thought the toroidal groove was the culprit. :oops:
quick61
Post by quick61 »
normandc wrote:Wow, didn't even notice that a plain old cylinder is affected. I thought the toroidal groove was the culprit. :oops:
Yup, looks like anything with a cylindrical OD has problems.
quick61
Re: [FIXED] Problems with Drawing WB?
Post by quick61 »
Thanks wmayer, working great, or at least like it was... Good enough until the old problems get hammered out.
Version: 0.15.4465 (Git)
Hash: c6fe925dfd4e0232b625c9fb4fa799dd113cfdac
Qt version: 4.8.6
Mark
