Cylinder part not drawing as a circle in projection
Bibi
Post by Bibi »
A simple part: Cylinder with a cylindrical cut out at 45 degrees, like so:
Part
Part
Should, in my mind, be drawn as a perfect circle when drawn as an orthographic projection in top view (drawing toolbench). However, it draws this funny shape:
Top view
Top view
Bottom view
Bottom view
Even though the shape is indeed funny, when viewing from the top or bottom the outer line is defined by the cylinder only, and should thus draw as a perfect circle. Or am I missing something?
The FreeCad file:
Cylinder non-circular.FCStd
FreeCad
(43.14 KiB) Downloaded 82 times
My version: (Same results in 0.14 and Mac)
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4346 (Git)
Hash: e329cb5c3acd5b170359e0e8cd28d98b61be935d
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
bejant
Re: Cylinder part not drawing as a circle in projection
Post by bejant »
Bibi wrote:when viewing from the top or bottom the outer line is defined by the cylinder only, and should thus draw as a perfect circle. Or am I missing something?
I don't think you're missing anything; and agree that there should not be any hidden lines when viewed from the top or bottom. Have a look at your model from the top and from the bottom...
NormandC
Post by NormandC »
Seems like you found a bug in the Drawing workbench. You could report it on the bug tracker. I think it has trouble projecting BSpline curves correctly.
FYI, if you create a Draft Shape2DView of your shape with direction set to (0,0,-1), the projected edge is circular as it should be.
The same happens when using the projection command of the Drawing workbench. And the interesting fact is that the edge doesn't only look circular but it's a real circle.
shoogen
Post by shoogen »
wmayer wrote:And the interesting fact is that the edge doesn't only look circular but it's a real circle.
It should theoretically be circular. But it isn't.
   1 : BSplineCurve
  Degree 8, 65 Poles, 10  Knots
>>> bsp.Degree,bsp.isPeriodic()
(8, False)
>>> bsp.getMultiplicities(),bsp.getKnots()
([9, 7, 7, 7, 7, 7, 7, 7, 7, 9], [0.0, 0.07, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 1.0])
shoogen
Post by shoogen »
The cuprit are bad parameters for the BSpline approximation, that is meant to reduce the degree for svg output.
OCCT makes a bad last segment instead of distributing the the error among all segments.
Allowing a coarser tolerance (currently 0.001 in drawing (and 0.05 in draft)) or more path segments (currently 10 in drawing (and 20 in draft)) solves the problem in this case.
https://github.com/FreeCAD/FreeCAD_sf_m ... t.cpp#L190
The problem there is that SVG doesn't support B-splines at all. AFAIK it only supports Bezier curves up to a degree of 3.
shoogen
Post by shoogen »
wmayer wrote:The problem there is that SVG doesn't support B-splines at all. AFAIK it only supports Bezier curves up to a degree of 3.
It works well for me. DXF is the one that shows serious problems.
issue #1898 target was set to 0.15
Do we need to bump it to 0.17 or some future release?
NormandC
Post by NormandC »
The problem appears to be fixed in
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
Forcing a recompute fixes the Drawing views.
