Artefacts when using a linear pattern
mfraz74
Post by mfraz74 »
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.0.31709 (Git) AppImage
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * sheetmetal 0.2.61
  * freecad.gears 1.0.0
  * Manipulator 1.5.0
  * lattice2 1.0.0
  * fcgear 1.0.0
  * Lithophane
  * Curves 0.6.5
  * Assembly4 0.12.4
  * InventorLoader 1.3.0
  * fasteners 0.4.54
  * A2plus 0.4.60i
  * QuickMeasure 2022.10.28
  * ThreadProfile 1.84.0
  * Assembly3 0.11.4
  * VendorParts
I've created a sketch and revolved it in the Part Design WB. I've then added a pocket and used a linear pattern to create multiple pockets, but as soon as I create the linear pattern artefacts are visible in the model and when exported.
Pattern Test.FCStd
(506.78 KiB) Downloaded 45 times
domad
Re: Artefacts when using a linear pattern
Post by domad »
mfraz74 wrote: Tue Jan 31, 2023 11:39 am ....
Hi mfraz74, hello to the Community!
I confirm the anomaly, I tried the export in *.stl and opened in Blender and Meshlab and the models have less evident anomalies in the same place but different in the conformation, however, leaving the angular deflection at 28° and bringing the deviation to 0, 02 anomalies also disappear in exports.
I enclose the modeling performed in "Part" using the original sketches interfaced with the "DynamicData" Wb to perform some dynamic changes in real-time, I have not encountered any problems.
I am also attaching the original file with the diversion setting reset as previously indicated which does not show any anomalies.
Pattern_Test_Dynamic_domad.FCStd
(151.13 KiB) Downloaded 28 times
Pattern_dev_0_02 Test.FCStd
(503.03 KiB) Downloaded 33 times
papyblaise
Post by papyblaise »
there is coplanar: the radius of the sketch are the same as those of the 1st body, increase them by 0.05mm
mfraz74
Post by mfraz74 »
papyblaise wrote: Tue Jan 31, 2023 3:07 pm there is coplanar: the radius of the sketch are the same as those of the 1st body, increase them by 0.05mm
I've removed that sketch and just created a padded circle, it's still showing artefacts.
papyblaise
I modified the sketch of the windows and its position, and that of the teeth, reversed the order of the pockets and the linearPatern, the result is good, but I did not identify which disturbs the site
Pattern TestPPB.FCStd
(66.68 KiB) Downloaded 41 times
Pattern TestPPB.JPG (21.02 KiB) Viewed 879 times
mfraz74
Post by mfraz74 »
papyblaise wrote: Wed Feb 01, 2023 9:04 am I modified the sketch of the windows and its position, and that of the teeth, reversed the order of the pockets and the linearPatern, the result is good, but I did not identify which disturbs the site
Still seeing artefacts
Do I report this as a bug?
papyblaise
I don't know what to say anymore, I don't see any at home and yet my version is older
someone else would have to confirm (Schlm en dit-il plus :?: )
Shalmeneser
Post by Shalmeneser »
Body > Property View > Deviation = 0.5 for better quality ?
FCuser2019
Post by FCuser2019 »
Hello, unfortunately the tessellation algorithm has serious problems in certain cases, this is an example.
Using the Draw Style "Hidden line" you have the following situation:
By decreasing the deviation to 0.1, the defect apparently disappears:
but in reality it is still present:
decreasing the deviation to 0.05, in the hope of obtaining correct tessellation throughout the body, gives the following horrible result:
Unfortunately, there are cases where no deviation value can correct the incorrect tessellation! :(
papyblaise
the mystery deepens: if I do the 1st revolution at 179° the artefact increases, if I do it at 181° all is well :?: :?: :?:
