I can't find the "non-solid"
drmacro
Re: I can't find the "non-solid"
Post by drmacro »
chrisb wrote: Sun Jan 29, 2023 5:54 pm
drmacro wrote: Sun Jan 29, 2023 4:39 pm I didn't attempt any operations. I opened the file, no errors. I also did a recompute with no errors.
Can you try to redo the top level cut?
Yes, that produces said message.
drmacro wrote: Sun Jan 29, 2023 6:01 pm Yes, that produces said message.
Thanks for confirming. @KDM, please create a ticket.
KDM
Post by KDM »
chrisb wrote: Sun Jan 29, 2023 4:01 pm
drmacro wrote: Sun Jan 29, 2023 3:41 pm Hmm...here it passes geometry check in FreeCAD.
The result here is ok as well. Do you too get the intermediate message with the non solids when you create the cut?
Yes, none of the above is a problem ... the problem only occurs at the moment I perform the cut. The Cut seems to succeed, but it moans about it.
KDM
Post by KDM »
chrisb wrote: Sun Jan 29, 2023 6:21 pm Thanks for confirming. @KDM, please create a ticket.
Heh heh, well you folks have been having fun with this. I'd like to participate at that level in the community, but until I understand what just happened, all I can really do is submit my file and my observations. Can you help me pad it a bit with useful info?
drmacro wrote: Sun Jan 29, 2023 3:41 pm Hmm...here it passes geometry check in FreeCAD. And the exported stl seems to pass the 3D print checks and manifold check in Blender.
Yes, for me also. I have now imported to CURA.
Shalmeneser wrote: Sun Jan 29, 2023 4:24 pm Just for PartDesign fans.
Got no idea what that means!
KDM
Post by KDM »
domad wrote: Sun Jan 29, 2023 5:40 pm It's not a bug but a surface intersection problem, you simply have to lower, on the "Z" axis, the cut sphere "Lug" by a few hundredths or thousandths of a mm, and everything will work.
This I understand! I do normally overlap solids before merging them. Some of the others think something more sinister is going on, though.
I deleted the cut operation, moved the lug down by 0.1mm, and re-did the cut .... It did not complain.
Thanks.
@chrisb is this still ticket-worthy?
Shalmeneser
Post by Shalmeneser »
For those who prefer PartDesign workbench.
domad
Post by domad »
KDM wrote: Mon Jan 30, 2023 10:51 pm This I understand! I do normally overlap solids before merging them. Some of the others think something more sinister is going on, though.
Hello KDM, greetings to the Community!
Unfortunately in FC, when there are situations in which the modeling algorithm is unable to determine the exact boundary between faces, a sort of "apparent intersection/interpenetration/interaction" is created which puts it in crisis, so it is enough to "force" a po and everything works again.
KDM wrote: Mon Jan 30, 2023 10:51 pm @chrisb is this still ticket-worthy?
Yes, I think so, as the message is very misleading. The developers may decide if improvement is possible.
