MMSN wrote: ↑Sat Jan 28, 2023 2:19 pm
MMSN
Probably I have guessed wrong but in FC (FreeCAD for short) you have Pad that is specifically a feature of PartDesign WB and extrude that is in Part WB (the only things confusing in FC is Part WB name, but you can live with it. Speaking of code Part module is not confusing at all)
I agree that some revision in terms on some area will be advisable, to reduce confusion, but in CAD there are many habits and sadly not unified way to describe operations, as different vendors use different names.
Part WB or better Part module can do both CSG and BREP and more complicated things too. (I mostly code my drawings so I use rarely the GUI to model things.)
But as you speak about yellow and blue I suppose you are referring to icons. There have been some discussion about revising some icons so probably in near future some thing will change, but changing is always problematic as for sure someone will complains.
Being in an international context maybe is not helping in understanding other people thought, but from others answers I'm not alone in having misunderstood your post.
Kind regards.
