[Solved] How to create a radially symmetric multitransform that "fans out" (Use Draft WB -> Circular Array)
physmage
Post by physmage »
OS: macOS 10.16
Version: 0.20.1.29410 (Git)
Locale: C/Default (C)
Hi, I'm wondering if there is a way to create a multitransform that fans out, increasing in frequency for each radial step. I.e. if the first polar transformation creates 6 copies of the feature, the second will create 12, the third 18, and so on.
The way I started was by applying a linear transformation to a pocket in the body I'm manipulating, then applying a polar transformation, but I'm left with wedges I would like to pocket in the way I described above without having to sketch an entire wedge of the holes to be pocketed then applying a polar transformation.
Any ideas?
Coffee_Filter_holder.FCStd
(449.48 KiB) Downloaded 10 times
Radial Symmetry Markedup.jpg (908.48 KiB) Viewed 850 times
Re: How to create a radially symmetric multitransform that "fans out"
What you are looking for is not available in PartDesign, but can be done with Draft->CircularArray. You have to create a separate body (or Part object) for the cutout, then create the array and subtract the whole array in Part workbench from the body (not from a feature inside).
drmacro
Post by drmacro »
Seems like a good application for Lattice 2 workbench.
papyblaise
Post by papyblaise »
that doesn't exactly answer the question
is there a solution so that the copies are all oriented towards the center
Coffee_Filter_holderPPB.FCStd
(903.31 KiB) Downloaded 8 times
Coffee_Filter_holder PPB.JPG (44.48 KiB) Viewed 607 times
papyblaise
I found: by orienting the hole perpendicular to the spiral
Coffee_Filter_holder2 PPB.JPG (52.7 KiB) Viewed 596 times
Here is the circular array version. Drawback: I cannot remove the single innermost instance:
Papyblaise: You should not apply Part booleans to PartDesign features.
Coffee_Filter_holder_cb.FCStd
(735.33 KiB) Downloaded 15 times
Jolbas
Post by Jolbas »
@chrisb Did you attach the correct document?
Jolbas wrote: Wed Jan 25, 2023 12:35 pm @chrisb Did you attach the correct document?
It was the wrong one. I replaced it in the post above.
papyblaise
I didn't do that
I didn't know about this circular array function
I also discover that the orientation of the copies towards the Z center depends on the orientation of the original with respect to the X axis
Let me explain: if the original is on the Y axis as it is in the original file, therefore perpendicular to X, it will rotate while remaining vectorially oriented to X
physmage
Post by physmage »
Thanks all for the replies.
@chrisb I like the version you made. Which parameter(s) did you apply to get the array sketches with the correct orientation? I've been comparing to an array I made and can't spot the difference. My array has each copy of the sketch rotated 90º like the example in the docs.
I think that I should be able to just make a copy of the first iteration and apply a polar transformation to solve the drawback you pointed out.
The one thing I noticed were that the vertices look particularly pronounced..that's not actually 3 dimensional though is it? It's not something that will show up when I go to 3D print this for example, right?
