[Solved] Polar pocket custom direction
yoshua
Post by yoshua »
The pockets are destined to be identical.
Pocket and polar array don't mesh well without help.
Is there a way to make LCS along the polar array , to change the XYZ of each pocket so LCS-orientation "follows" the polar transform?
Update; solved it was simple :oops: ... Array the pocket
polar pocket custom direction solved.FCStd
(42.39 KiB) Downloaded 14 times
Bance
Re: [Solved] Polar pocket custom direction
Post by Bance »
What were you trying to pattern before?
This is a picture of a broken model......
Snip macro screenshot-44f6b1.png (57.63 KiB) Viewed 318 times
Shalmeneser
Post by Shalmeneser »
You do not need Part wb.
Yours 'slot' sketch is too complex.
Annotation 2022-12-07 114938.jpg (33.49 KiB) Viewed 292 times
Boite a Meuh_SHALM.FCStd
(261.94 KiB) Downloaded 13 times
