I'm changing my laser tag gun design that I made in FreeCAD to use chamfers instead of fillets, to improve printability, but I ran into a problem: FreeCAD is giving me bad results when I try to convert my variable-radius fillet to a chamfer.
Please note that this is a Part fillet, and it doesn't actually use the "Variable Radius" option, but rather has multiple different radii along the curve, which are interpolated automatically.
When I try to reproduce this same behavior with a chamfer, the closest result that I've been able to get is this:
Is there some way to make this work? I've tried everything that seemed to have some possibility of working. I tried using the "Variable Length" feature on the chamfer, but found that that feature was actually referring to chamfers with different angles. I've tried this on 0.19.3, 0.20, the weekly release (2022-12-04), and the Link Branch (22.07.09), and none of them work when I try to make that chamfer. Given that the Part chamfer allows specifying multiple chamfer lengths, I would consider its failure to produce a result that even loosely matches the parameters to be a a bug. Is there any work-around that I can use, or any plan to fix this?
All versions of FreeCAD that I specified were running on Ubuntu 22.04 from AppImages, though I have little reason to believe that that information has any relevance.
Equivalent feature for chamfers: variable-length fillets?
Re: Equivalent feature for chamfers: variable-length fillets?
You can create the chamfers manually with a sweep and multiple sections.
That results in its own problems, as I mentioned in https://forum.freecadweb.org/viewtopic.php?f=3&t=74832, so your workaround doesn't work without another workaround for its problems.
