Hallo,
I want to build a framework from a warbles structure.
When I create warbs in Sketcher, how do I fill them as body, without them becoming surfaces?
How do I pad only edges?
- warbe.jpg (40.01 KiB) Viewed 541 times
- Wabe.FCStd
- (8.35 KiB) Downloaded 9 times
Re: How do I pad only edges?
The Target should be something like this
- korb.jpg (752.63 KiB) Viewed 531 times
To make this you should use the Pyramids-and-Polyhedrons workbench
- papyblaise
Honeycomb in French?
uses Wall from Arch Wb
- nid d'abeille.FCStd
- (20.29 KiB) Downloaded 12 times
- nid d'abeille.JPG (24.75 KiB) Viewed 511 times
You can try Arch->Wall. For the correct angles there is a special attachment mode . There is also an addon macro for polyhedrons.
Ahh nice, wall should be a nie solution.
But how can I Transform a strukture like that to an cubic object?
- papyblaise
et je dirai même plus .......You can try Arch->Wall.
- thomas-neemann
