[Bug?] TechDraw.findOuterWire(shape.Edges)
xc22143
Post by xc22143 »
Hello, everyone!
I used TechDraw.findOuterWire to get the outlines of the edges. However, it seemed that the outer wire is not the outer lines.
the edges are:
the outer wire using TechDraw.findOuterWire:
Actually, the edges are from the result of face.project(the green faces).
However, when I tried TechDraw.findShapeOutline(green faces, 1.0, App.Vector(0,1,0)), the result is right.
is it a bug? Thank you for help!
Here is the FC file.
find outer lines.FCStd
(59.92 KiB) Downloaded 12 times
Re: [Bug?] TechDraw.findOuterWire(shape.Edges)
Moved from developer forum.
Works here flawless:
OS: macOS 10.16
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.6.1
wandererfan
Post by wandererfan »
xc22143 wrote: Sun Dec 04, 2022 9:53 am is it a bug? Thank you for help!
If you are starting from a 3d shape, you should use findShapeOutline as it projects the shape, then looks for the outer wire. findOuterWire doesn't do a projection and assumes the edges are all in the same plane.
xc22143
Post by xc22143 »
wandererfan wrote: Sun Dec 04, 2022 1:32 pm If you are starting from a 3d shape, you should use findShapeOutline as it projects the shape, then looks for the outer wire. findOuterWire doesn't do a projection and assumes the edges are all in the same plane.
Thank you! I used face.project(3D shape) to get the edges, so the edges should be in the same plane. So before findOuterWire, the projection was done.
xc22143
Post by xc22143 »
chrisb wrote: Sun Dec 04, 2022 10:48 am
Thank you! Could you share the specific operations?
xc22143 wrote: Mon Dec 05, 2022 1:37 am Thank you! Could you share the specific operations?
Of course:
- load the file
- select top view
- select "Face"
- switch to TechDraw
- add view
