I am new in FreeCAD and use version 0.20.1
The problem is that when I try to create pocket the whole model fails.
I don't understand what I am doing wrong. I red about topological naming problem and decided to recreate the last sketches based
on datum planes but still have weird result.
Can you help me understand what I am doing wrong?
Simple model fails when try to make a pocket
- test1.FCStd
- (286.92 KiB) Downloaded 9 times
- Screenshot 2022-12-03 194409.png (152.59 KiB) Viewed 573 times
Re: Simple model fails when try to make a pocket
Try:
Note that the last Pocket has to be adjusted: it does not produce holes.
- Right-click the top node in the Tree view.
- Select "Mark to recompute".
- Call Std_Refresh.
There is a problem with the last pocket (Part_CheckGeometry) but a full recompute sanitize the file.
You do not need DatumPlane here. Why DatumPlane001 has no Map Mode ?
You should not sketch upon face. Same for DatumPlane.
Use only sketch upon XY-plane. (you do not need to stack material, you can add it through other material.)
Thank you very much for your replays.
Recompute fixed the issue.
I know that maybe my questions are silly, but would like to have better understating of how the things are working.
I don't completely get this. If I want to make certain geometry on the of the object how can I do it without sketch over the top face?You should not sketch upon face. Same for DatumPlane.
Is it possible to make Pad or Pocket with offset?Use only sketch upon XY-plane.
- Capture d’écran 2022-12-03 200835.jpg (86.88 KiB) Viewed 494 times
- Attach me_SHALM.FCStd
- (18.4 KiB) Downloaded 7 times
Thank you for the help!
Tutorial is really good also
Since you are looking at attachment information. I'd be interested to hear your comments on this playlist about the subject.
https://www.youtube.com/playlist?list=P ... 8DxQMK8cDG
Since I only know the Flat Face method, I need that.drmacro wrote: ↑Sat Dec 03, 2022 11:41 pm Since you are looking at attachment information. I'd be interested to hear your comments on this playlist about the subject.
Reading, watching and learning now. Thanks.
