Where is the format of an exported Points file documented?
keithsloan52
Post by keithsloan52 »
I export a points cloud and it looks like
# ASCII
6.66134e-16 -4.44089e-16 -30
2.44052 4.8342e-16 -29.0929
4.89042 2.0422e-15 -26.1678
7.07107 1.04057e-15 -21.2132
8.7226 4.0844e-15 -14.6713
9.69762 3.86736e-15 -7.32157
10 1.77636e-15 -9.86076e-32
5.03195e-16 3.41853e-16 -30
I have a program that creates a point cloud for a different application it looks like
OFF
8194 16384 16388
0.5773502691896258 0.5773502691896258, 0.5773502691896258
-0.5773502691896258 -0.5773502691896258, 0.5773502691896258
-0.5773502691896258 0.5773502691896258, -0.5773502691896258
0.5773502691896258 -0.5773502691896258, -0.5773502691896258
0.0 1.0, 0.0
-1.0 0.0, 0.0
0.0 0.0, 1.0
0.0 -1.0, 0.0
1.0 0.0, 0.0
0.0 0.0, -1.0
0.32505758367186816 0.8880738339771151, 0.32505758367186816
0.0 0.7071067811865475, 0.7071067811865475
0.32505758367186816 0.32505758367186816, 0.8880738339771151
-0.7071067811865475 0.7071067811865475, 0.0
-0.7071067811865475 0.0, 0.7071067811865475
-0.8880738339771151 -0.32505758367186816, 0.32505758367186816
-0.32505758367186816 -0.32505758367186816, 0.8880738339771151
-0.32505758367186816 0.8880738339771151, -0.32505758367186816
-0.8880738339771151 0.32505758367186816, -0.32505758367186816
0.8880738339771151 0.32505758367186816, 0.32505758367186816
I edited as follows and gave it a file extension of asc but nothing is displayed on import using the Points workbench
# ASCII
# 8194 16384 16388
0.0 1.0, 0.0
-1.0 0.0, 0.0
0.0 0.0, 1.0
0.0 -1.0, 0.0
1.0 0.0, 0.0
0.0 0.0, -1.0
Had to add txt to file extension to load to forum
exportedPoints.asc.txt
(2.85 KiB) Downloaded 7 times
jeno
Re: Where is the format of an exported Points file documented?
Post by jeno »
keithsloan52 wrote: Sat Dec 03, 2022 2:24 pm Where is the format of an exported Points file documented?
# ASCII
OFF
8194 16384 16388
Afaik FC exports only plain XYZ coordinates of an vertex in one line separated by a blank.
X Y Z
X Y Z
a.s.o
ObjectFileFormat contains data about vertices, faces and edges
cheers
keithsloan52
Still no luck with this version
PointFileEdited.asc.txt
(475.98 KiB) Downloaded 11 times
Roy_043
Post by Roy_043 »
Get rid of the commas.
jeno
Post by jeno »
keithsloan52 wrote: Sat Dec 03, 2022 5:36 pm Still no luck with this version
It works here flawlessly
I tried also a surface reconstruction with meshlab (see part mesh)
cheers
keithsloan.FCStd
(447.85 KiB) Downloaded 9 times
keithsloan52
jeno wrote: Sun Dec 04, 2022 7:54 am
cheers
FreeCAD version?
I am
OS: macOS 10.16
Version: 0.20.29177 (Git)
Locale: C/Default (C)
  * ImportNURBS 1.1.0
  * ImportExport_3DM 0.1.0
  * GDML 2.0.0
  * Alternate_OpenSCAD 1.0.0
  * toSketch 1.0.1
  * Curves 0.6.4
jeno
Post by jeno »
keithsloan52 wrote: Sun Dec 04, 2022 8:25 am
cheers
FreeCAD version?
I'm running on
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.1.29410 (Git)
Branch: makepkg
Python 3.10.8, Qt 5.15.7, Coin 4.0.1, Vtk 9.1.0, OCC 7.6.3
  * Defeaturing 1.2.0
  * Curves 0.5.12
  * sheetmetal 0.2.58
cheers
keithsloan52
Roy_043 wrote: Sat Dec 03, 2022 5:56 pm Get rid of the commas.
Thanks
