[BUGGY but solved]: 0.20.1 often the shadowing disappear
BartR
Post by BartR »
Windows 11 Pro 64 bit
On a solid, when I go back from
Going from
View > Draw Style > No Shading
to
View > Draw Style > Shaded
it's ok but when I'm back to
All the visibility is flatted down (see the attachment) and I'm not able to re-establish it.
I have to restart FreeCAD to get it back.
Is it a recon bug? Or is there a way to get it normal in another and more simple way?
______________
Bart R.
Re: 0.20.1 often the shadowing disappear
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
BartR
Post by BartR »
chrisb wrote: Sat Dec 03, 2022 10:49 am Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
I understand the rules but it does on any project. Not matter the complexity. And it's "random" ... I mean not always ... but often I found my slef into this situation
______________
Bart R.
drmacro
Post by drmacro »
BartR wrote: Sat Dec 03, 2022 10:53 am
But, not knowing what hardware, OS, and FC version, we have no idea whether it;s a hardware issue, software bug, difference because of the version, etc.
In other words we need a crystal ball to scry what might be. ;)
Bance
Post by Bance »
BartR wrote: Sat Dec 03, 2022 10:53 am I understand the rules but it does on any project. Not matter the complexity. And it's "random" ... I mean not always ... but often I found my slef into this situation
It never happened to me......
But maybe I'm using a different version to you? We can't tell because you didn't follow the rules even though you know them.
BartR
Post by BartR »
drmacro wrote: Sat Dec 03, 2022 11:02 am
I wrote the version on the title.
Os Windows 11 Pro
______________
Bart R.
drmacro
Post by drmacro »
BartR wrote: Sat Dec 03, 2022 11:05 am
Os Windows 11 Pro
Is it such a onerous task to click Help>About, click "Copy to clipbord", and paste here? :?:
Version: 0.21.31109 (Git) AppImage
Hash: c23ee7ad88433a0f00e84afae0a62fe738be0c09
  * Manipulator 1.4.9
  * Defeaturing 1.2.0
  * Curves 0.5.15
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * fasteners 0.4.23
  * A2plus 0.4.60d
  * sheetmetal 0.2.59
  * CurvedShapes 1.0.4
  * lattice2 1.0.0
BartR
Post by BartR »
drmacro wrote: Sat Dec 03, 2022 11:09 am Is it such a onerous task to click Help>About, click "Copy to clipbord", and paste here? :?:
  * Manipulator 1.4.9
  * Defeaturing 1.2.0
  * Curves 0.5.15
  * fasteners 0.4.23
  * A2plus 0.4.60d
  * sheetmetal 0.2.59
  * lattice2 1.0.0
No it isn't as far as FreeCad is reporting correct version of the OS ... so: not like in this case.
It's NOT Windows 10 Version 2009 but Windows 11 Pro version 21H2 ... Build 22000.1281
@Bance following the rules: the reported data about the OS is wrong.
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * 3D_Printing_Tools
  * ArchTextures
  * CADExchanger
  * Curves 0.6.1
  * fasteners 0.4.24
  * fcgear
  * InventorLoader 1.3.0
  * kicadStepUpMod 10.16.5
  * pcb
  * POV-Ray-Rendering
  * Render 2022.3.0
  * ThreadProfile 1.84.0
  * WebTools
______________
Bart R.
BartR
Post by BartR »
I found the way.
Just select the last feature of A body (no matter which one):
Right Click > Set Colors > Set to Default
and everything comes back to normal without to restart the project of worse: FreeCAD.
Not clue if it's a bug or an anomaly: it occurs.
______________
Bart R.
BartR
Re: [BUGGY but solved]: 0.20.1 often the shadowing disappear
Post by BartR »
@Bance I see that the menu help etc, doesn't report graphics card etc ... what if this is due graphic card/driver issue?
Hence: not only the report is partially wrong, but also uncomplete ...
______________
Bart R.
