Is it possible to loft with 2 Guide rails
Paulmac66
Post by Paulmac66 »
I have 2 sections i want to create a solid between the 2 sketches, which works fine as a loft, but i need to control the loft with 2 guide curves, the bottom edge is flat/planar, the top edge is a radius.
i have used additive pipe which works but again only allows 1 guide curve
i am used to using much higher end Cad systems (CATIA, NX, Solid Edge, Solid Works...), and this is simple to do.
But i am a total Newbie on Freecad
Thanks for any help
Freecad 0.20
Rev 29177
Red Hat
64 Bit
Bance
Re: Is it possible to loft with 2 Guide rails
Post by Bance »
Try the curved shapes addon from addon manager...
Paulmac66
Post by Paulmac66 »
Thanks, can you suggest which command to use, so i can find out if it will do what i want before i add it on
drmacro
Post by drmacro »
Paulmac66 wrote: Wed Nov 30, 2022 2:05 pm Thanks, can you suggest which command to use, so i can find out if it will do what i want before i add it on
Just add it. It takes up almost no resources.
Bance
Post by Bance »
If you don't like the addon its easily removed. They are modules.
