PolarPattern with Z-axis shift depending on the function of angle
Re: PolarPattern with Z-axis shift depending on the function of angle
Eventually found a solution. Fantastic is Lattice2.
- Capture2.JPG (23.49 KiB) Viewed 235 times
- Special_PolarPattern.FCStd
- (185.28 KiB) Downloaded 12 times
I found a way, using your parametric curve - but I needed to make an array of vertical construction lines at the cylinder locations. Otherwise I could not figure out how to get the correct attachment there.
- Special_polarpattern_EW.FCStd
- (121.62 KiB) Downloaded 12 times
