PolarPattern with Z-axis shift depending on the function of angle
Hi All!
I'd like to make 20 holes in a cylinder. The main problem is that the holes must be shifted in Z-axis using sinus function like this:
- hole number 1: shift = sin(0 * 360/20) * shift_amplitude = sin(0deg) * shift_amplitude
- hole number 2: shift = sin(1 * 360/20) * shift_amplitude = sin(18deg) * shift_amplitude
- hole number N: shift = sin((N-1) * 360/20) * shift_amplitude
How to make such PolarPattern?
Best regards,
Jacek
Best regards,
Jacek
Best regards,
Jacek
Jacek
Re: PolarPattern with Z-axis shift depending on the angle
PolarPattern cannot do this. Have a look at Draft PolarArray if it fits your needs. It can do Z offsets.
Thank you for the answer, chrisb.
Unfortunately, I can't find PolarArray tool. May you direct me, please?
Best regards,
Jacek
Jacek
- papyblaise
it's that
- hole helix.JPG (29.83 KiB) Viewed 965 times
- hole helix.FCStd
- (138.74 KiB) Downloaded 21 times
drmarco, thanks for the answer.
However, how may I reference current angle to make the position dependent on it?
Best regards,
Jacek
Jacek
Thanks! It looks very nice. I will take a look
Best regards,
Jacek
Jacek
Unfortunately, the holes are placed linearly, not in positions pointed by the sinus function. Any idea, how to fix it?
Best regards,
Jacek
Jacek
- papyblaise
you need a powerful counter to calculate Z = Z Total /Number of Holes
- hole helix Z.JPG (59.08 KiB) Viewed 715 times
