Hi, I could not find anything in the search, even though I doubt this has not been asked yet.
I would find it helpful if I could coincide the (end)points of two lines (selected via subelements) , which I drew via arch/draft into space (without sketcher), so that if I move one line, the other one follows (preferably only that subelement).
I do realize that I am pretty much asking for all the sketcher features but in 3D.
This could e.g. be helpful when drawing walls in Arch, where I could move one wall (to resize a room) and the adjacent walls would just readjust in order to keep touching the moved wall. Or in my case a roof truss (using nodes and Arch structures), where I could dynamically set the rafter distance (on a roof with non-parallel walls, resulting in a change of angle for each rafter depending on where it is located in the roof).
Draft/Arch: Coincide Points of Lines (Subelements)
- papyblaise
Re: Draft/Arch: Coincide Points of Lines (Subelements)
it's so easy with sketching and construction lines using equalities
in my example you change the distribution from 450mm to what you want at once, or the total width and the division will be automatic
- charpente.JPG (22.8 KiB) Viewed 569 times
- charpente.FCStd
- (13.85 KiB) Downloaded 7 times
I don't know if it fits the bill but have you tried ArchSketch?
https://forum.freecadweb.org/viewtopic.php?f=23&t=73018
@Bance wow, this looks very promising!
It would most likely solve the issue with walls and may be even roofs, but we will see.
@papyblaise thank you for showing this. Often when I am wishing for features there is usually a more simple solution to it.
I feel quite confident when it comes to constraining sketches. What I am less confident with is the positioning of these sketches in space and constraining them with external geometry. I will open a new topic for this, because the question of this topic has been answered.
Just for the record: My angles are somewhat different from what you have depicted. Luckily they are at least parallel, but unfortunately not parallel to the ground plot of the house, neither north nor south of the south (even though it looks like on the top view). @papyblaise what would be your approach of solving this, because I for sure am using to many sketches and draft lines which I have to rearrange manually once I change the slightest dimension (ground plot, height of the roof etc.).
- Dachgeschosswohnung_richtigerGrundriss.FCStd
- (590.15 KiB) Downloaded 9 times
- Dachstuhl_Top_FCforum.jpg (82.63 KiB) Viewed 475 times
- Dachstuhl_Front_FCforum.jpg (45.99 KiB) Viewed 475 times
- papyblaise
you pose a riddle to me, my proposal is suitable for a "mansard" roof but yours is "left" more relevant to marine architecture or aircraft wing
I would do the west rafters first, then the east attic on each plan of each rafter a sketch with external references to draw the east rafter
would take longer than making a simple Array
You can use expressions to control the start and endpoints of Draft Lines. See the attached example.
- warped_roof_lines.FCStd
- (8.04 KiB) Downloaded 13 times
Now that [[expression] is wicked!
Do I have to know the vertexes (points) by heart or is there any chance of selecting it from 3D or a list?
Probably I can find some help on expressions somewhere...
Documentation: Expressions.
There is an autocomplete feature for names, labels, properties and spreadsheet aliases, but not for subelements of the Shape property.
In the example Draft Lines were subdivided, this will result in a logical sequence of vertices. After creating the first expression, you can just copy paste and raise the index for subsequent expressions.
