TempPath is not respected
FredCailloux
Re: TempPath is not respected
Post by FredCailloux »
Yes, I did try it but no success.
Great results only comes with great understanding. Great memory is just an illusion.
FredCailloux wrote: Sun Dec 04, 2022 7:18 pm Yes, I did try it but no success.
It is not sufficient to specify the path (as chennes pointed out, it works well without), but you have to configure it in Preferences->General>Document. Check both hooks "Run auto recovery at startup" and "Save auto recovery every ...".
There is nothing to say against newbies, but I admit that I am bit disappointed that every idiot newbie post without any file attached or FreeCAD infos or whatever else we like to have finds more support than my request for validation.
So I finally created - not knowing which one to use - an issue and a problem report: issue #7995, issue #7996.
GeneFC
Post by GeneFC »
chrisb wrote: Fri Dec 09, 2022 8:47 pm my request for validation.
I did not quite understand the issue when this first came up, and I then just passed over this topic. :oops:
In any case, I have always used a custom temp location, and I have never had any problems. I just checked again and everything seems to be working correctly.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
  * FeedsAndSpeeds 0.5.0
  * FeedsAndSpeeds-master.zip
  * freecad.gears 1.0.0
  * Help 1.0.3
Gene
Thanks for the feedback, so it may be a macOS issue. Would be interesting to hear about Linux as well, as the file system seems to becloser to mac's.
chrisb wrote: Fri Nov 25, 2022 2:10 am The parameter BaseApp→Preferences→General→TempPath is no longer respected. It points to the directory, where the auto recovery files are stored.
Note, that when implementing the XDG specification more than a year ago TempPath is not used any more to save recovery files. Instead the location pointing to QStandardPaths::GenericCacheLocation is used. On a standard Linux system this is now under $HOME/.cache/FreeCAD/Cache/.
So, the user doesn't have to worry about changing this path to a directory that survives a reboot. From the GUI you can easily access this directory via Edit > Preferences > General > Cache. There is a line field with the path name and a convenience button to open a file manager window. Additionally there are options to automatically clean-up the directory if too much garbage has been collected over time.
wmayer wrote: Tue Dec 27, 2022 12:08 pm when implementing the XDG specification more than a year ago TempPath is not used any more to save recovery files.
Thanks for the information. I will check the situation on macOS later.
