TempPath is not respected
The parameter BaseApp→Preferences→General→TempPath is no longer respected. It points to the directory, where the auto recovery files are stored.
Does it still work on Linux and Windows?
OS: macOS 13.0
Version: 0.21.31035 (Git)
Hash: c8074a972ee233d303e50e5d525aecae09c1cd04
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.5.8
thomas-neemann
Re: TempPath is not respected
Post by thomas-neemann »
chrisb wrote: Fri Nov 25, 2022 2:10 am ...
how can you test that?
This is based on a description of Werner:
Bildschirm­foto 2022-11-25 um 22.07.49.png (228.55 KiB) Viewed 774 times
FredCailloux
Post by FredCailloux »
What exactly is to understand from the previous post ?
My question is in regards to the "Save AutoRecovery information every" ( say 5 minutes )
When this parameter is set to 5 minutes on a Windows 7 system, does that mean that the current work is saved every 5 minutes ?
Where is it saved by default ? ( I cant find the location on my system )
From the previous post, If the "TempPath" is not set in the Parameter/BaseApp/Preferences/General/
Does this mean that the "Save AutoRecovery information every" will not necessarily save any file ?
FreeCAD behavior is not clear to me.
Great results only comes with great understanding. Great memory is just an illusion.
FredCailloux wrote: Sun Dec 04, 2022 2:52 am When this parameter is set to 5 minutes on a Windows 7 system, does that mean that the current work is saved every 5 minutes ?
Yes. Even if you don't specify the path it is saved in some temp directory. If FreeCAD crashes that is ok. But if the system crashes, it may clean up your temp folder and your work will be lost.
@edwilliams16, you are on MacOS as well. Would you mind testing this?
FredCailloux
chrisb wrote: Sun Dec 04, 2022 9:35 am Yes. Even if you don't specify the path it is saved in some temp directory. If FreeCAD crashes that is ok. But if the system crashes, it may clean up your temp folder and your work will be lost.
So, on a Windows 7 system Is there a default folder location where this backup file would be stored ?
What would be that folder ? In my case it is not c:\Windows\Temp\
Right now I'm afraid to restart FreeCAD from fear of loosing my 3h work.
In my case it was a FreeCAD crash. The system was still working properly when it happened.
If there exist any possibility to retrieve my work I'm going to wait for that answer. Thanks
chennes
Post by chennes »
It isn't FreeCAD you have to worry about deleting your work, it's your operating system. When you start FreeCAD, it will examine the TempPath (whatever it may be) and see if there are autorecover files there. If there are, it will offer you the chance to load them. The above discussion concerns a crash that forces your whole computer to reboot, which in some cases erases the temp directory. So just don't reboot: launch FreeCAD.
Chris Hennes
Pioneer Library System
FredCailloux
From fear of loosing my work I immediately added the TempPath in the Parameter/BaseApp/Preferences/General/
Thinking, at least, the next time this happen I will not loose my work.
But now, even restarting FreeCAD, nothing is suggested. that is why I was hoping FreeCAD had previously saved this work in a default temp folder.
It would appear that it is not the case since FreeCAD is not suggesting anything at startup.
chennes
Post by chennes »
FredCailloux wrote: Sun Dec 04, 2022 5:41 pm It would appear that it is not the case since FreeCAD is not suggesting anything at startup.
I'd guess now FreeCAD is only looking in your newly-specified temp path, not in its default. You can try deleting that parameter and see if FreeCAD re-discovers its lost temp files.
Chris Hennes
