Bug Freecad 0.20.1, MacOS Ventura, Freecad crashes when using part design
I created my project using an older Freecad 0.20 version (I guess May 2022). Suddenly Freecad crashed when I was creating / using a DatumPlane and Sketch editor. It seems that even the FCStd file was lost and need to use an older saved file version. This was really annoying.
So I switched to newest version of Freecad 0.20.1 Revision number 29410. It still crashes when I work in my project file (maybe sporadically).
Thereon, when I try to reopen the FCStd file, freecall tells that "The file xxx" cannot be opened". Freecad does not tell why it cannot be opened. My work seems to be destroyed.
Is it an issue with the new MacOS Ventura version that I installed one week ago?
Should I try to use a new Freecad Weekly developer build?
Is the FCStd damaged by using the older FreeCAD version and this cannot be recovered by newer Freecad version?
Is it a known issue?
- 2022-11-06_macos_crash-log.txt
- (109.46 KiB) Downloaded 18 times
- PVModul-Unterkonstruktion_T3-5_S355_80x80x6,3_1x_2022-11-03.FCStd
- (225.84 KiB) Downloaded 17 times
Re: Bug Freecad 0.20.1, MacOS Ventura, Freecad crashes when using part design
Hi and welcome to the forum!
Please attach always your full FreeCAD info as described in the IMPORTANT forum rules linked above.
I have no problem opening the file in 0.21, please try that. If the error persists, create a log file by starting FreeCAD with the additional parameter --log-file.
You sketches are too complex.
- PVModul_SHAL2M.FCStd
- (180.32 KiB) Downloaded 17 times
Hi, I am now switched to newest weekly build. Revision 31109.
But I created a new project and try to save but the folder remains empty. No error message at all. Freecad shows it with the new file name in tree.
Then, when I try to open it from recent file list, there is an error message "path + cannot be opened". The folder is shown as empty in macos finder.
So I am unable to save the work.
Your request: "create a log file by starting FreeCAD with the additional parameter --log-file."
./MacOS/FreeCAD --log-file trace.txt
See attached file.
I loaded an older project version. Tried to sava as... with another name.
There is no error at all. The file cannot be found in filesystem (Not okay). Then I exit the program.
There is no error log in trace.txt that explains the problem.
See attached file.
- trace.txt
- (14.22 KiB) Downloaded 14 times
Some errors logged in terminal on next startup and try to load the non-existing FCStd file
2022-11-27 16:24:54.694 freecad[3647:171719] Path given to -[NSWorkspace iconForFile:] is not a full path.
[36541127/162455.159433:ERROR:command_buffer_proxy_impl.cc(141)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.[*]
My current issue is that I am not able to save the freecad project at all. I am using the newest Mac OS version 13.0.1 Ventura.
I ran the following commandline to execute the tests
./MacOS/FreeCAD --run-test 0
See txt file
See txt file
- trace_tests.txt
- (680.66 KiB) Downloaded 18 times
Strange.
At a specific parent folder, I am able to save the file.
I am sure I never changed file permissions and the whole path uses the same hard disk.
Maybe could it be a problem that the name of sub folder contains a problematic character "ä"?
Nevertheless, Freecad should check whether the saved file exists and give feedback if missing. I think this should be improved.
This version does some fancy things asking for permissions. Perhaps you inadvertently denied them?Dagobert2021 wrote: ↑Sun Nov 27, 2022 3:29 pm My current issue is that I am not able to save the freecad project at all. I am using the newest Mac OS version 13.0.1 Ventura.
