Render-Error after new Plane
edgeHB
Post by edgeHB »
Hey community,
i just started to learn FreeCAD yesterday but today i ran into a problem, i'm not able to solve myself. I used the search, but i probably don't know the correct lingo yet.
FreeCAD Version:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * A2plus 0.4.59d
File:
Deckenhalter_Lampe.FCStd
(44 KiB) Downloaded 12 times
Problem:
I created a Body based on two Sketches:
1st sketch = the "base"
2nd sketch = a pocket
looks good so far:
I now added another plane (according to this video: https://youtu.be/4uEwHB7LciA?t=720) and a third sketch on that plane, to create another pocket.
The first thing that was frustrating was, that the new rectangle for that (in Sketcher) was behind the existing pads and when i turned the existing pad and pocket off and only sketches on, the existing sketches were not drawn. So i had to "freestyle" the positioning and pocketing. (I'm sure that is a user issue ;) ).
The second thing is, that the 3D View of the body is destroyed and does not display, what (i thought) i drew. When i turn off the Pocket001, the model looks fine again:
I'm sure, that i did something wrong, but i would appreciate some help!
Re: Render-Error after new Plane
Hi and welcome to the forum!
You should upload the file so we can inspect it. For communicating your version, follow the IMPORTANT forum rules linked above.
edgeHB
Post by edgeHB »
Thanks, added the informations :)
A full recompute of the whole model fixes the issue.
Concerning your sketches: To have less clutter on the screen and to better show the intrinsic geometry of a sketch, it is advised to minimize the number of dimensional constraints. See the attached file for examples.
Deckenhalter_Lampe_cb.FCStd
(20.22 KiB) Downloaded 11 times
Shalmeneser
Post by Shalmeneser »
Sketch : Map Reversed = true
or Transparency = 50% (Std_SetAppearance)
Pocket : Reversed box : ok
edgeHB
Post by edgeHB »
chrisb wrote: Wed Oct 05, 2022 7:37 pm A full recompute of the whole model fixes the issue.
Thanks so much! That helped :)
I'll now look at your file.
... oh and i found the chamfer now... that would have saved me some work :)
edgeHB
Post by edgeHB »
Shalmeneser wrote: Wed Oct 05, 2022 7:39 pm Sketch : Map Reversed = true
Thanks, i need to do more research about that :)
