key to show sketch plane
FCuser0
Post by FCuser0 »
I have a very basic problem that - as simple as it seems - I cannot solve:
I am looking for a keyboard shortcut to show a sketch "flat", i.e. rotated so that its plane coincides with the screen. Basically the view one gets when one opens the sketch. I tried HOME and several shortcuts found in the view menu, but none seems to do the trick.
(of course one could use a standard view for sketches in XY, XZ etc. In my case the sketch is in a datum plane that is "at an angle", so that this does not work)
I guess I should add that I use the 0.20.1 AppImage.
freedman
Re: key to show sketch plane
Post by freedman »
I'm presuming your not in Sketch edit mode from your post.
Goto Edit->Preferences->Sketcher->Display, uncheck Restore camera position after edit and click Apply to existing sketches. Now when you close the sketch the view will stay the same.
drmacro
Post by drmacro »
The View sketch tool. Image
Shortcut keys are shown as Q P when you hover over the icon. Or, in the Sketch menu>View sketch.
Bance
Post by Bance »
Use the view sketch tool:-
FCuser0
Post by FCuser0 »
Q, P was the solution. Thank you!
