kisolre
Posts: 4166 Joined: Wed Nov 21, 2018 1:13 pm
Post
by kisolre » Sat Oct 01, 2022 4:52 pm
I wanted to try the new clipping plane direction switching when looking from back of the sketch and noticed that the dimension numbers were not visible. Dimension lines and other constraint numbers/symbols are still visible. This happens with or without clipping plane active.
Edit:
Here is a clip
Version: 0.21.30485 (Git)
Hash: 8924e265c068c2446a091f84c83c8b1934451470
Python 3.8.8, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Bulgarian/Bulgaria (bg_BG)
* 3DfindIT 1.2.0
* A2plus 0.4.56a
* AirPlaneDesign 0.4.0
* AnimationFreeCAD 1.0.0
* ArchTextures
* Assembly3 0.11.3
* Assembly4 0.12.3
* BIM 2021.12.0
* BOLTSFC
* CfdOF 1.17.7
* CubeMenu
* CurvedShapes 1.0.4
* Curves 0.3.0
* CycloidGearBox
* Defeaturing
* Design456 0.0.1
* DesignSPHysics 0.6.1-2207-03-01
* dodo
* DynamicData 2.46.0
* ExplodedAssembly
* fasteners 0.3.51
* fcgear 1.0.0
* FCPDWorkbench 0.2.0
* FEM_FrontISTR 0.1.0
* frame 0.1.0
* freecad.xray 2022.4.17
* FreeCAD_mcm_addon
* Help 1.0.3
* InvGears 0.1.2
* kicadStepUpMod 10.14.5
* lattice2 1.0.0
* Launcher
* MakerWorkbench
* Manipulator 1.4.9
* Mechatronic
* MeshRemodel 1.8919.0
* MnesarcoUtils 0.1.0
* Nikra-DAP
* nurbs
* OpticsWorkbench 1.0.8
* ose-piping
* parts_library
* PlacementTools
* Plot 2022.4.17
* Pyramids-and-Polyhedrons
* Reinforcement
* Render 2022.2.0
* Rocket 2.6.1
* SearchBar 1.0.1
* SelectorToolbar
* sheetmetal 0.2.56
* Ship 2022.4.11
* Silk 1.0.0
* SlopedPlanesMacro
* StemfieWB
* symbols_library
* ThreadProfile 1.82.0
* toSketch
* Woodworking 0.20.29177
* workfeature
* workfeature-macro
kisolre on Sat Oct 01, 2022 10:08 pm, edited 1 time in total.
thomas-neemann
Posts: 11964 Joined: Wed Jan 22, 2020 6:03 pm
Post
by thomas-neemann » Sat Oct 01, 2022 6:14 pm
kisolre wrote: ↑ Sat Oct 01, 2022 4:52 pm
where can I find the new clipping plane direction switching?
kisolre
Post
by kisolre » Sat Oct 01, 2022 7:20 pm
This might be misleading. I was referring to "View Section" command. Now when in Sketch Edit mode and "View Section" is active if you rotate the view and look from the back of the sketch the clipping direction changes automatically and the part of the model what is in front of the sketch (sketch local Z direction) becomes visible and what is behind the sketch (sketch local -Z direction) is hidden.
But sadly the dimension numbers disappear.
thomas-neemann
Post
by thomas-neemann » Sat Oct 01, 2022 7:36 pm
kisolre wrote: ↑ Sat Oct 01, 2022 7:20 pm
thanks for the information. If I understood you correctly, it works here
Version: 0.21.30486 (Git) AppImage
Hash: eb546e25d3f952869e3ec87dca02b58653cb3936
kisolre
Post
by kisolre » Sat Oct 01, 2022 10:07 pm
Here is a clip of the problem. I don't think its a settings or something.
thomas-neemann
Post
by thomas-neemann » Sun Oct 02, 2022 6:08 am
kisolre wrote: ↑ Sat Oct 01, 2022 10:07 pm
can you upload the file?
openBrain
Posts: 9041 Joined: Fri Nov 09, 2018 5:38 pm
Post
by openBrain » Sun Oct 02, 2022 7:03 am
@kisolre What's the behavior if you create the dimension when on the back side, then rotate to front side?
thomas-neemann
Post
by thomas-neemann » Sun Oct 02, 2022 10:30 am
I tried to replicate your situation. here it works
kisolre
Post
by kisolre » Sun Oct 02, 2022 11:05 am
openBrain wrote: ↑ Sun Oct 02, 2022 7:03 am
Same.
Tried this:
New file.
New sketch.
Draw rectangle.
Create dimension - Ok.
Rotate view from back - dimension number dissapears.
Create dimension while still looking from the back - dimension is created but the number is not visible.
Rotate view to front - both dimension numbers are visible.
kisolre
Post
by kisolre » Sun Oct 02, 2022 11:17 am
Also tried NVidia:
14:09:45 OpenGL version is: 4.6 (4.6.0 NVIDIA 445.75)
14:09:45 Run Gui init script
14:09:45 Init: Running FreeCADGuiInit.py start script...
14:09:46 Init: Searching modules...
14:09:53 Init: Initializing E:\FC_DevVMBuild\Mod\AddonManager... done
14:09:53 Init: Initializing E:\FC_DevVMBuild\Mod\Arch... done
14:09:53 Init: Initializing E:\FC_DevVMBuild\Mod\Draft... done
14:09:53 Init: Initializing E:\FC_DevVMBuild\Mod\Fem... done
and Intel integrated:
14:14:53 OpenGL version is: 4.4 (4.4.0 - Build 21.20.16.5068)
14:14:53 Run Gui init script
14:14:53 Init: Running FreeCADGuiInit.py start script...
14:14:53 Init: Searching modules...
14:14:54 Init: Initializing E:\FC_DevVMBuild\Mod\AddonManager... done
Same behavior.
