Can't Additive Pipe a shape
Steve76063
Post by Steve76063 »
I've been trying to 'sweep' a shape around the outline of another shape (I actually did this on an older project). Now, whenever I select the small shape and select Additive Pipe, I immediately get a 'Recompute failed! Please check report view' error!
ps. I can do a Pad with the small shape, so I think it's a closed shape.
I'm not so much looking for someone to fix it for me, but I'd like to know just how to track down the cause of the error and fix it myself (so I can use that skill in the future).
Any enlightenment?
Small shape and path I want to follow
Recompute Failed.FCStd
Project for FC 0.20
(11.35 KiB) Downloaded 18 times
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * 3D_Printing_Tools
  * fasteners 0.3.46
  * Help 1.0.3
  * Lithophane
Shalmeneser
Re: Can't Additive Pipe a shape
Post by Shalmeneser »
1) select form
2) select path (+Ctrl)
3) Pipe tool
no problem with :
OS: Linux Mint 20.3 (MATE/mate)
Version: 0.21.30398 (Git) AppImage
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
Locale: French/France (fr_FR)
  * Manipulator 1.4.9
  * fasteners
  * sheetmetal 0.2.50
  * fasteners.bak
Capture du 2022-09-30 23-43-43.png (12.8 KiB) Viewed 607 times
Steve76063
Excellent...I was selecting the shape, then hit Additive Pipe and hit the error.
Using your method, I selected the shape, Ctrl-selected a portion of the path, and got part of my sweep. Under Object, I selected another part of the sweep path and it filled it in all the way.
I'll have to remember your method - again, thanks.
Steve76063 wrote: Fri Sep 30, 2022 9:39 pm I'm not so much looking for someone to fix it for me, but I'd like to know just how to track down the cause of the error and fix it myself (so I can use that skill in the future).
This was discussed in the past (and I thought it had been fixed :? ): The error is a false positive, shown because you haven't selected a path yet. If you simply ignore it, and you select a path in the panel, then it works. I could understand a warning, but it is definitely no error, because there isn't anything really wrong yet.
If you would confirm the sweep without having selected a path, then of course an error should be shown.
This is indeed a regression. In this version ...
OS: macOS 10.16
Version: 0.19.24291 (Git)
Branch: (HEAD detached at 0.19.2)
Python version: 3.8.8
Qt version: 5.12.9
Locale: C/Default (C)
... I can select just a section and invoke the sweep without an error.
Steve76063
Thanks, that explains how I did a sweep before without seeing this 'error'...I was using 0.19.
