"Go to the linked Object" does not open the object as it is.
leoheck
Post by leoheck »
The "Go to the linked Object" button, opens the linked object but the internal organization of the file is missing. For instance, folders/groups are missing.
I am using Assembly 4, but don't know if this matters, actually.
Version: 0.21.30454 (Git) AppImage
Hash: 5df954690787dedbbf3c35f658f010f388474676
  * Defeaturing 1.2.0
  * Part-o-magic.backup1662467294.9039905
  * A2plus 0.4.59c
  * Curves 0.5.8
  * fasteners 0.4.12
  * lattice2 1.0.0
  * Assembly4 0.12.4
  * kicadStepUpMod 10.15.1
  * Help 1.0.3
Re: "Go to the linked Object" does not open the object as it is.
I think this is due to partial load of the document, I'm not sure how to fully load a document or if it should be fully loaded when using this command.
Roy_043
Post by Roy_043 »
This behavior is intended. You can double-click a partially loaded document in the Tree view to fully open it.
leoheck
Post by leoheck »
Roy_043 wrote: Wed Sep 28, 2022 4:50 pm You can double-click a partially loaded document in the Tree view to fully open it.
Oh, nice, thanks.
What is the goal of partially loading it?
Having a quick view?
What if I edit it and then save it, is it going to mess with the files organization?
leoheck wrote: Wed Sep 28, 2022 5:19 pm What is the goal of partially loading it?
When you open a document that links to another the linked document is only partially loaded for performance reason, only the linked objects are loaded. I don't think this has negative effects when you save changes.
leoheck
Post by leoheck »
Ah, you are saying that the operation does is not open the file that is being linked.
You are saying that it is opening a view of the file that relies on inside the current file.
I thought the "go to the linked object" was accessing the real file of that object.
This is not useful for me, then.
Do you know if I can open a file that is being linked in an easy way?
It is opening the actual file, but just what is already loaded, I was just explaining why the document is only partially loaded. I can see why you would want to fully load the file when clicking go to linked object but I can also why in some cases it can be enough and better to just show the partially loaded document.
Zolko
Post by Zolko »
leoheck wrote: Wed Sep 28, 2022 5:54 pm Do you know if I can open a file that is being linked in an easy way?
in the Assembly4 WB, right-click on the link in the tree, and choose "Open Document".
leoheck
Post by leoheck »
Gotcha, thank you Zolko and adrianinsaval!
leoheck
Post by leoheck »
Zolko wrote: Wed Sep 28, 2022 6:13 pm in the Assembly4 WB, right-click on the link in the tree, and choose "Open Document".
Hey Zolko, this is equal to the "Go to Linked Object".
My question was regarding if there is a way to easily open a file that is being linked in the "full mode" not the partial mode.
