[Solved: Toponaming] Changing base sketch breaks Part Design
Cadder
Post by Cadder »
Hi, in Part Design sketches and their elements can completely break next steps as all attachment to faces, edges, etc. is done just via element names, not via some immutable id.
So if we add/remove edge/face in base sketch/object this attachment could become completely broken. I believe it's something widely known, is there open bug, workaround?
Is it worth to give example, or everybody encounter this problem?
Thanks.
Re: Changing base sketch breaksPart Design
Cadder wrote: Sat Sep 24, 2022 4:20 pm or everybody encounter this problem?
Yes, everybody knows it and with much luck there will be improvements in the next version. If you follow the advice for creating stable models you can drastically improve stability of your models. There remain only few tools relying on generated geometry such as chamfer, fillet, thickness.
Cadder
Post by Cadder »
Shalmeneser wrote: Sat Sep 24, 2022 4:21 pm Topological_naming_problem aka TNP
I was sure I'm not alone :lol:
chrisb wrote: Sat Sep 24, 2022 4:40 pm advice for creating stable models
Unfortunately it adds a lot of work - instead of just stick to needed place/reference user need calculate positions. :(
I'll try realthunder fork.
Thanks you all!
drmacro
Post by drmacro »
Cadder wrote: Sat Sep 24, 2022 5:22 pm
Thanks you all!
I know it is an unpopular opinion... But, slapping sketches on generated geometry with reckless abandon is not necessarily good practice. With or without TNP.
But, you are correct, the Linkstage3 version will allow this sort of modeling. But, even there TNP is only mitigated, not 100% gone.
Yes, there are those who say, it is good enough that it is like being 100%...but, if it is that good, then the tools provided to fix it aren't necessary, right? 8-)
Cadder
Post by Cadder »
drmacro wrote: Sat Sep 24, 2022 5:54 pm slapping sketches on generated geometry with reckless abandon is not necessarily good practice
May be from scientific point of view it's not good, but for me, as home user making models for 3D printing ability bind object to some corner or side is "must have" feature.
drmacro
Post by drmacro »
Cadder wrote: Sat Sep 24, 2022 6:26 pm
I understand that many aren't interested in advanced skills or even long term model maintenance. And that ok to. ;)
Re: Changing base sketch breaks Part Design
You can use Realthunder's Link branch if you want where he has a solution of toponaming. But learning how to use datum planes makes models more sustainable and transferable between CAD programs easier.
drmacro
Post by drmacro »
Cadder wrote: Sat Sep 24, 2022 5:22 pm ... user need calculate positions. :(
For the record, this not true.
