OS: macOS 10.16
Version: 0.21.30398 (Git)
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
Locale: C/Default (C)
* Behave-Dark-Colors 0.1.1
* CurvedShapes 1.0.4
* Assembly4 0.12.3
This is of course less nice if it is a centre circle lines type marker, when due to a change in PartDesign the actual centre of the hole is now slightly off. Until now, unfortunately, the "cosmetic" objects are not editable.
Now I realise that the "cosmetic" objects are actually just a snapshot of the past if the design behind them should change. One must be able to correct drawing errors if one can recognise such when looking through the drawings. In this case, however, the correction starts in the construction at the level of PartDesign and inevitably Techdraw must be able to follow. All this would not be so bad if one could delete the "cosmetic" objects, but TechDraw counters with the argument "You cannot delete the anchor view of a projection group". Who wins? At the moment I get the impression that I am one of the few users who deal intensively with TechDraw. OK, that's not bad if you can turn the insights into solutions.
