how can I join the two parts in the attached file to create a funnel?
Create a funnel
Create a funnel
- funnel.FCStd
- (18.65 KiB) Downloaded 21 times
Re: Create a funnel
PartDesign_AdditiveLoft
(You could do everything with a one big loft with 4 sketches)
- funnel_SHALM.FCStd
- (145.76 KiB) Downloaded 22 times
- Capture d’écran 2022-09-22 072550.jpg (58.9 KiB) Viewed 826 times
Re: Create a funnel
Thanks for your answer. I modified it a little bit.
So here i have one question more. How can I cut out the tube from the loft which is painted in red in the attachment.
- cut.png (53.34 KiB) Viewed 701 times
- funnel hole.FCStd
- (699.25 KiB) Downloaded 10 times
- papyblaise
Re: Create a funnel
make a Datumplan that goes through the 2 connection lines between the faces and the fillet
and Pad up to plan
and a Datumline in the center to make an Array
and Pad up to plan
- funnal.FCStd
- (691.16 KiB) Downloaded 20 times
- funnal.JPG (12.03 KiB) Viewed 641 times
Re: Create a funnel
Thank you. I rebuild your additional elements in the body. That works great
Re: Create a funnel
- FunnelHole_SHALM.FCStd
- (572.54 KiB) Downloaded 19 times
- Capture d’écran 2022-09-24 142248.jpg (44.35 KiB) Viewed 581 times
