I don't have time to post pics but in the MWE I noticed that I can click fit all once to get a 50% full screen and then click fit all once again and I get 80% full screen, it appears the double zoom is somewhat orientation dependent. Never tried clicking twice before this test.
Edit: It could be that the code fix is just to call zoom fit twice. I'm guessing one call would center the view and the next is a fill screen. Just guess work.
Win 20.289
Why is Standard View Fit All too small for assemblies(4)?
- adrianinsaval
Re: Why is Standard View Fit All too small for assemblies(4)?
perhaps LCS affects the bounding box? Or something else? In your problematic example use Std_SelBoundingBox and click each object to check what is giving a bigger bounding box than it should (start with the top level).
The inner box is the outer steel rim of the wheel. The next is the spoke array. The next, wheel sub-assembly. The largest is the top assembly Model.adrianinsaval wrote: ↑Fri Sep 23, 2022 6:08 pm In your problematic example use Std_SelBoundingBox and click each object to check what is giving a bigger bounding box than it should (start with the top level).
So, if the FitAll is based on the bounding box then it is easy to see why the assembly is too small. Now, the question is why is the top assembly bounding box too large?
This next image shows all of the LCS's and datum in Model. The LCS axes curiously get relatively larger as the the view shrinks. That must set the size of the bounding box.
"It is a poor workman who blames his tools..."
- adrianinsaval
when you select an LCS, does it have a bounding box?
No. Same for any datum line or plane.adrianinsaval wrote: ↑Sat Sep 24, 2022 12:22 pm when you select an LCS, does it have a bounding box?
