wandererfan wrote: ↑Thu Aug 25, 2022 12:34 pm
I believe this is referring to the small text beside the cursor when moving sketch objects.
I see this. Yes, the numbers are metric.
Mouse Grid.jpg (55.97 KiB) Viewed 1033 times
I never use the dimensions, since I almost always want to just get the object close enough to apply actual constraints. Attempting to position by using a "grid" can easily lead to problems with elements remaining unconnected.
@GeneFC That's exactly what I'm talking about, the X, Y mouse coordinate. From other parametric software packages I've used, it's very helpful to me. If I tell FreeCAD that I want inches to 4 decimal places, that's what I want to see. So it is an undocumented feature.
@openBrain I see the float in the line you are referencing in the C++ file. I would rather just install FreeCAD and configure it in the GUI; I'm all about the easy. Thanks for pointing this out though.
So there isn't a way to configure inches to 4 decimal places in the GUI, even though I entered the correct settings???
FreeCADnewb! wrote: ↑Thu Aug 25, 2022 9:15 pm
I suspect this little item is totally unaware of the unit settings in Preferences.
I still have this nagging feeling that you are heading toward disaster. Sketcher is based on constraints, not on position accuracy to 4 decimal places. But that is just me.
@GeneFC When drawing a part, I don't use the inches at 4 decimal points to be exact, I use it to get me really close so I can get a reference to what I'm drawing and then I use size constraints after.
Do the developers monitor this forum? If not, could someone report this undocumented feature to the developers?
There are approx 40 places where the cursor text is set in Sketcher/Gui and none of them are unit aware. Here is one of them changed to display units. (Haven't figured out how to make a screen grab without moving the cursor out of view. )
wandererfan wrote: ↑Fri Aug 26, 2022 6:41 pm
Classic problem!
I use the Print Screen key on the keyboard and then cut the resulting image down to the appropriate size. Usually allows the cursor or some selection to be shown.
@wandererfan Do you think those approximately 40 places in Sketcher/GUI should be unit aware? As a user, some might enjoy that feature. Your second image, sketcherCursorDisplay_decimalInch.png, is what I would like to see. Apparently you know where to configure FreeCAD to display what I'm looking for. Could you please share where those settings are or what you did?
FreeCADnewb! wrote: ↑Fri Aug 26, 2022 10:57 pm
It isn't configurable. I changed the code in 1 of the 40 places to see what it would look like.
Sketcher currently displays the coordinates in reduced precision (1.2 instead of 1.2345). To duplicate that in a unit aware fashion is a pita. Displaying the coordinates showing the unit and the number of decimals from the Units preference tab is much easier.
I don't use the coordinate display, so I need some feedback from the community on the acceptability of showing (1.2345 mm, 6.7890 mm) vs the current (1.2, 6.7). Showing multi-unit schema (say Ft/In or DMS) values in reduced precision looks particularly nasty.
