What is the possibility to change the planes afterwards?
In the previous exercises, it didn't really matter which of the planes you selected. If you now create an object on the wrong plane, what possibility is there to change it later?
Re: What is the possibility to change the planes afterwards?
Which exercises?
It is possible to change the support Property.
If a sketch has attachment (as they usually do,) it is attached to a support.
Don't you know where the properties are?
Reorient sketch is perfect for planes and faces - of which we actually don't recommend to use the latter. For a more general approach you can use the AttachmentDialog.
