Chamfer is driving me nuts :-)
NHSA_Rainer
Post by NHSA_Rainer »
I am making some timing gears and everything goes well until I want to apply a 0.25mm chamfer to the slot of the thick part of the gear.
Why is FreeCAD not accepting to do it ? I have redrawn several times this piece and still no luck.
Thanks Rainer
GT2_20d.FCStd
(681.93 KiB) Downloaded 15 times
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Spanish/Latin America (es_419)
  * AnimationFreeCAD 1.0.0
  * fcgear 1.81.0
  * Help 1.0.3
  * ThreadProfile 1.81.0
Re: Chamfer is driving me nuts :-)
Chamfers (and fillets) are sometimes a bit picky. This comes from the third party kernel, the FreeCAD developers cannot fix it.
Here you can apply the chamfer as soon as possible, i.e. directly behind Pocket.
Shalmeneser
Post by Shalmeneser »
1) Fillet the 4 lines inside the slot hole. (r=0.01 mm)
2) Chamfer one side of the slop opening.
Imho, chamfer doesn't like the non-tangent border of the slot opening.
Capture d’écran 2022-08-11 024030.jpg (17.18 KiB) Viewed 1128 times
Shalmeneser wrote: Thu Aug 11, 2022 12:43 am Imho, chamfer doesn't like the non-tangent border of the slot opening.
That's right, but there must be more in it, because it can work as described above:
GT2_20d_cb.FCStd
(433.48 KiB) Downloaded 14 times
Shalmeneser
I cannot 1mm-chamfer the slot opening. :cry:
* selecting the upper face : FAIL
* selecting the 4 edges of the slot : FAIL (even modifying the order of selection)
ChamferTheSlot.FCStd
(16.6 KiB) Downloaded 13 times
Capture d’écran 2022-08-11 030047.jpg (39.12 KiB) Viewed 1109 times
papyblaise
Post by papyblaise »
I change the order of operations: the slot , then chamfrein , round pocket , then chamfrein
GT2_20d-1.FCStd
(494.82 KiB) Downloaded 16 times
papyblaise wrote: Thu Aug 11, 2022 6:21 am I change the order of operations
See my post above :)
papyblaise
See my post above
desole , I sliping tonight :lol:
domad
Post by domad »
NHSA_Rainer wrote: Wed Aug 10, 2022 8:55 pm ....
Hi NHSA_Rainer, hello to the Community!
The animated gif shows an example of the possibility of inserting a chamfer that is independently "editable" dynamically horizontally and vertically through the use of a "fictitious" Sketch that has the sole function of controlling the dimension of the chamfer.
GT2_20d_dynamic_chamfer.FCStd
(806.01 KiB) Downloaded 13 times
Shalmeneser
@domad :
* You should modify the position of the slot hole sketch to reuse the same sketch for the pocket and for the Pipe path.
* Sketch009 is outside the body for visibility, just to drive the dimensions of the chamfer. A spreadsheet should do the same but less cryptic.
