Unwanted residual after substraction
Tankgunner
Post by Tankgunner »
Hello everyone,
I'm new to FreeCAD, and experiencing this problem. A face from additive helix remains floating in the body, so Part_CheckGeometry reports error
The mistake can be traced up to the first step after Additive Helix (Cylinder), when I'm trying to fill the gaps, to get a solid body with threaded outer shape.
I wonder how to fix it. I can trace the badly located face, but can't remove it manually.
Many thanks to answer.
The file is located here (4mb) https://drive.google.com/file/d/1yADuid ... sp=sharing
UPDATE. I solved it myself. Draft workbench -> Draft_downgrade -> delete face -> Draft_Upgrade -> [the new Shell is fine with no errors ]-> Part Convert to Solid
Hope it will help someone.
If there are ways to evade such faults with helixes or easier solutions for errors, I will still be glad to read and try.
Alexey (Tankgunner)
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * fasteners 0.3.50
  * Manipulator 1.4.9
  * ThreadProfile 1.81.0
Shalmeneser
Re: Unwanted residual after substraction
Post by Shalmeneser »
The AdditiveHelix and 1st Cylinder should not be coplanar (17 mm in the two steps, try 16.999 for one).
You should avoid coplanar faces and seams. Your model shows errors already for the first added cylinder. They vanish if I reduce the cylinder's radius to 16mm. I didn't continue, because the model broke due to topological naming problems, caused by sketches attached to generated faces.
Edit: Shalmeneser found the culprit faster :) .
Shalmeneser
My model is just for ideas :idea:
CapPasCap_SHALMv2.FCStd
(776.96 KiB) Downloaded 8 times
Capture d’écran 2022-08-09 152250.jpg (60.77 KiB) Viewed 596 times
Tankgunner
Chrisb, Shalmeneser, thank you! :D
Coplanar issue seems to be useful.
Best regards,
Alexey (Tankgunner)
There is the Thread for Screw Tutorial, where you should look at the "Tips for success" for more pitfalls to avoid.
Tankgunner
chrisb wrote: Tue Aug 09, 2022 4:47 pm There is the Thread for Screw Tutorial, where you should look at the "Tips for success" for more pitfalls to avoid.
Thank you chrisb! I've studied through it before, seems have to re-read again.
Alexey (Tankgunner)
Tankgunner wrote: Wed Aug 10, 2022 3:29 am Thank you chrisb! I've studied through it before, seems have to re-read again.
In short it is:
- most important: no self intersections, i.e. no overlap of the helix turns!!
- no coplanar faces
- no helix start on a seam
There are some more:
- refining a helix can lead to problems in later steps
- if a helix looks distorted, it can help to change the segment length
