[Solved] accessibility to my network drives
Hello everyone, I am a new user of freecad, so I downloaded it and opened it to see how it works but I was quickly stopped by the impossibility of accessing my network drive of my nas server in which it is located my files.
Is it not possible to work on network files? do I have to import them locally to work?
Thank you for your help.
Re: accessibility to my network drives
Hi. We even don't know your OS...
Anyway, you can try to add the "DontUseNativeDialog" parameter and switch it to true/false. You can search for this parameter name and you'll find other thread with details on how to set it.
Hi, Sorry, my system is running windows 10, 64bits
No problem using network files in Windows. I do it often.
The difficulty almost certainly comes from some sort of permissions problem in Windows.
Gene
Gene
A priori, I see my network drive and I was therefore able to load my mechanical .step file that I am trying to modify.
- adrianinsaval
so it's working then? I don't understand
I am using FreeCAD for quite a while now and although new to this forum , I am following the discussions here quite regularly. Guys, you are doing an excellent job!
I am happy that I am not alone with my problem. So I decided to register.
I can confirm the access problem with a NAS. For a couple of versions writing to a NAS device is no longer possible although reading access works. I am running an up to date Windows 10 64Bit on two different computers with the same error. The last working version of FC is the Conda weekly build 29393. All higher version can load files from the NAS but cannot write them back. Moreover, the new versions may make trouble with some virus scanners. With the Microsoft defender everything is ok, with the Norton Antivirus software the FreeCAD.exe will be removed from the system. This happened to me two days ago with the latest 29485 version. The same happened some days earlier with another piece of program (crx.exe?) from an older version of the 29485.
Sorry for describing the error so unprecise, but I have no idea how to get more specific information out of my computer(s).
Achim
Achim
Regards from Teltow, Germany
Achim
Achim
the latest version at least solved the virus scan issue. However, trying to write on my NAS still results in an "unknown exception data"
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
* 3D_Printing_Tools
* A2plus 0.4.54b
* AirPlaneDesign 0.4.0
* Assembly4 0.11.8
* BOLTSFC
* CurvedShapes 1.0.0
* Curves 0.3.0
* fasteners
* Manipulator
* MeshRemodel 1.8918.0
* nurbs
* Plot
* Render 2022.1.0
* Ship
* Silk 764074112.0.0
Achim
Achim
I just discovered: exporting a file (I have tested the STL format) works fine...
Regards Achim
Regards Achim
Achim
Achim
I did a bit more checking.
Version 0.21.29393 and earlier work fine for reading and writing.
Version 0.21.29485 and later read OK but fail on write (save). (Also tested on 0.21.29825 compiled on 28-07-2022.)
The error message is
I usually read and write locally, so I did not see this recent problem until testing. As can be seen, the various libraries are identical, so there was either something changed in the FreeCAD master code or some unlisted library that causes the problem.
[Edit] Did a further bit of checking and the problem is likely due to either commit
https://github.com/FreeCAD/FreeCAD/comm ... 1ac06d4b6f
and/or
https://github.com/FreeCAD/FreeCAD/comm ... 5f3004af99.
Gene
OS: Windows 7 SP 1 (6.1)
Version: 0.21.29393 (Git)
Hash: 6820e0a9ec85203a6f342ca72a2ff8fd417beaf1
* FeedsAndSpeeds 0.4.0
* FeedsAndSpeeds-master.zip
* Help 1.0.3
* offline-documentation
* Help 1.0.3
<class 'Base.FreeCADError'>: boost::filesystem::weakly_canonical: The specified path is invalid
and/or
Gene
