How to draw horn-shaped object
fcbuilder
Post by fcbuilder »
Hi
I'm not an advanced user of any CAD, been using FreeCAD for half a year and still learning it.
The object on the right is what I'm trying to draw
I use Sketch workbench to sketch each section of the object which has different height and shape
Then I'll use loft or sweep from Part workbench to create solid
But it's a bit time consuming. Not to mention if there's a change in design, I have to change each section individually.
Is there a faster way to draw this? How do you guys usually draw objects like this?
Also how do you move or rotate sketches? I go to "placement" to adjust its xyz
OS: GNU/Linux
Version: 0.19
Word size: 64-bit
Release date: 2021/03/17
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
NewJoker
Re: How to draw horn-shaped object
Post by NewJoker »
For the path, check this thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=16604
When it comes to profiles, maybe videos about Nautilus shell modeling in other CAD software will give you a hint. I haven't found any examples of this being prepared in FreeCAD.
mfro
Post by mfro »
This is only a very quick and sloppy sketch, but just to show Additive Pipes can have a single point as end section and the start section does not necessarily need to be located on the path.
If I had to do this right, I would create the path as several adjacent one turn spirals with decreasing diameter.
horn.FCStd
(103.33 KiB) Downloaded 39 times
Cheers,
Markus
kohnagha
Post by kohnagha »
For me there seem to be too many Profiles, maybe 5 or so should be way enough. Attach your Profile-Sketches "normal to Edge" to the Path, use one single continuous (editable) Path. Position the Profiles with the "MapPathParameter" on this Path to easy move/add/delete/change the profiles.
hammax
Post by hammax »
... spiral sweeps are rather simple.
But the intended shape of your "horn" is not so clear to see.
Have a look at file "another_horn", built with CurvesWB.
another_horn.FCStd
FC.20.1
(28.31 KiB) Downloaded 26 times
fibonacci sweep_2.FCStd
FC.20.1
(34.92 KiB) Downloaded 23 times
hammax
Post by hammax »
... using CurvesWB you can create complex 3D-spirals for sweeppath.
Create hull curve and map a path on the surface.
Profiles at your will at start and end by FrenetNB (and between)
or parallel to Z.
another_horn_4.FCStd
(71.78 KiB) Downloaded 22 times
another_horn_3.FCStd
(224.49 KiB) Downloaded 22 times
another_horn_2.FCStd
FC.20.1
(31.2 KiB) Downloaded 22 times
papyblaise
Post by papyblaise »
pouet-pouet
pouet-pouet-2.FCStd
(236.41 KiB) Downloaded 27 times
kohnagha
Post by kohnagha »
Look out for arithmetic expresions of Horns, eg this http://paulbourke.net/geometry/spiral/
Compute xyz-Points, connect Points with splines, cover splines with the "Approximate"-Tool in curves-WB, make solid with Part-WB Offset-Tool.
#http://paulbourke.net/geometry/spiral/
# --> Mathematical Sea Shell Created by Paul Bourke May 1989
import FreeCAD, math, Draft, Part
import numpy as np
# n: number of spirals
n=2
# a: final shell radius
a=10
# b: height
b=40
# c: inner radius
c=8
smin=0
smax=2*math.pi
tmin=0
tmax=2*math.pi
#ts_otr = list()
ts_inr = list()
for t in np.arange (tmin, tmax ,0.05):
	ts_inr = list()
	for s in np.arange (smin, smax , 0.1):
		x = a * (1-t/(2*math.pi)) * math.cos(n*t) * (1+math.cos(s)) + c*math.cos(n*t)
		y = a * (1-t/(2*math.pi)) * math.sin(n*t) * (1+math.cos(s)) + c*math.sin(n*t)
		z = (b*t/(2*math.pi)) + a * (1-t/(2*math.pi)) * math.sin(s)
		#Draft.makePoint(FreeCAD.Vector(x,y,z))
		ts_inr.append(FreeCAD.Vector(x,y,z))
	Draft.makeBSpline(ts_inr,closed=True, face=False)
	#ts_otr.append(FreeCAD.Vector(x,y,z))
#Draft.makeBSpline(ts_otr,closed=False, face=False)
