I have a problem that the Mesh Design workbench specifically the "Create Mesh from Shape" when invoked does not popup a panel to select mesher and parameters. Anybody else able to verify.
keithsloan52 wrote: ↑Mon Jul 11, 2022 8:59 pm
I get this dialog as usual here:
You can retry with 0.21, but I would rather start with resetting the config file.
Would you mind changing the title of the topic? Besides that I would say it is at least two forward and one back, a more descriptive title like "Dialog for mesh options missing" could help others to find this discussion.
Please could you post your FreeCAD info for FreeCAD 0.20, ( 0.21 is pre-release).
Surprised at the large variations in versions between used subsystems for the various operating systems, surely that does not help with testing and getting things stable.
keithsloan52 wrote: ↑Fri Aug 12, 2022 8:13 am
Tried resetting config by moving
You need to properly reset back to a new user by renaming the Mod folder holding all those Addons and renaming your system.cfg (I know there's not a lot in there).
Having now seen this report and your report on compounding wires failing I'd say all the issues are down to some (probably minor) corruption on your machine and the chances of someone remotely pinpointing where I would suggest is going to be very difficult.
I moved Mod to Mod.save and system.cfg to system.cfg.save
Now I cannot install any of the previous workbenches, so one step forward THREE backwards - VERY Frustrating
