Gizmo Object in FreeCAD v20
SBlade
Post by SBlade »
Is there any gizmo object in FeeeCAD to be used when we transforming element moving, rotating and scaling the scene objects ?
Roy_043
Re: Gizmo Object İn FreeCAD v20
Post by Roy_043 »
NewJoker
Post by NewJoker »
For scaling you will need another tool: Draft Scale
The rest can be done using the Transform tool mentioned above or add-on Manipulator Workbench.
SBlade
Post by SBlade »
Thank you very much, interestingly transform works only for primitive objects but not for ArchPrecast objects which was my actually intentions. Any work around to make it work for ArchPrecast objects as well?
SBlade
Post by SBlade »
Dear All,
Any guidance on that will be appreciated.
SBlade wrote: Mon Jun 27, 2022 9:33 am Thank you very much, interestingly transform works only for primitive objects but not for ArchPrecast objects which was my actually intentions. Any work around to make it work for ArchPrecast objects as well?
Bance
Re: Gizmo Object in FreeCAD v20
Post by Bance »
There seems to be some urgency? Maybe if you follow the posting rules a more appropriate answer will be s forthcoming....
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Roy_043
Post by Roy_043 »
SBlade wrote: Mon Jun 27, 2022 9:33 am Any work around to make it work for ArchPrecast objects as well?
Put the object in a Std_Part.
