Datum Point or Line ¿ how to reference in part Separador ?
NHSA_Rainer
Post by NHSA_Rainer »
I have been trying to set a Datum Point or Line 94mm from the 0,0 origin in the center of the big clamp in order to create a groove in the same way I created it on the small clamp.
I thought setting a Datum Point or a Datum Line as rotation center would allow me to rotate a slot and the groove it around that Datum Point or Line.
Have been trying for a while to get it active but to no avail.
File
Antena_Avion.FCStd
(259.51 KiB) Downloaded 13 times
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Spanish/Latin America (es_419)
  * fcgear
  * ThreadProfile
edwilliams16
Re: Datum Point or Line ¿ how to reference in part Separador ?
Post by edwilliams16 »
Attach the Datum Line this way:
Screen Shot 2022-06-25 at 8.36.27 AM.png (67.79 KiB) Viewed 479 times
NewJoker
Post by NewJoker »
Define a datum line like this:
freedman
Post by freedman »
Here is how I would do it. Mapmode can be very helpful. You can map a datum line to the curve center, then map a datum plane to the datum line, then sketch on the datum plane that has an axis of the curve. Here is an example.
There are some possibilities of TNP because of a mapped edge but this is parametric.
Antena_Avion_bac.FCStd
(323.47 KiB) Downloaded 5 times
(323.47 KiB) Downloaded 8 times
drmacro
Post by drmacro »
You can also add a construction line to the sketch for the Groove:
Antena_Avion-mac.FCStd
(305.83 KiB) Downloaded 8 times
Snip macro screenshot-c2a97e.png (117.21 KiB) Viewed 474 times
NHSA_Rainer
edwilliams16 wrote: Sat Jun 25, 2022 6:38 pm Attach the Datum Line this way:
Thanks. Tried that several times but never was able to use the Datum line as revolving center.
Bance
Post by Bance »
Make the solid invisible and sketch visible, select one of the inner radii and select the DL.
done
edwilliams16
Screen Shot 2022-06-25 at 9.13.47 AM.png (15.16 KiB) Viewed 423 times
EDIT: Added the FCStd file...
Antena_Avion_EW.FCStd
(422.43 KiB) Downloaded 6 times
NHSA_Rainer
freedman wrote: Sat Jun 25, 2022 6:41 pm Here is how I would do it. Mapmode can very helpful. You can map a datum line to the curve center, then map a datum plane to the datum line, then sketch on the datum plane that has an axis of the curve. Here is an example.
Thanks and this did the trick. I made a Datum Line and then added a datum Plane and so I was able to get the groove around it.
NHSA_Rainer
drmacro wrote: Sat Jun 25, 2022 6:42 pm You can also add a construction line to the sketch for the Groove:
Did not know how to use a construction line as a reference for grooving or maybe pocketing. Thanks.
Tested this method and in my case it only works choosing an angle of 359°. With 360° I only get the groove on one side.
Does this have something to do that it is not a full solid in 360° ?
Groove on one side not present = 360°
Groove present as wished = 359°
