Handle hanging portions of object
bhs67
Post by bhs67 »
FreeCAD 0.20
Printing this (from Thingiverse)
results in hanging strands for the tail, chin, and belly. I can add some supports (via PrusaSlicer), but that is cumbersome. Is there a standard procedure that makes it easy to print without dangling strands?
Shalmeneser
Re: Handle hanging portions of object
Post by Shalmeneser »
1) 0.20 are not your full info
2) This is a 3D printing problem and not a FC problem. The slicer is the best tool for this.
NewJoker
Post by NewJoker »
Maybe try printing this model laid on its side.
papyblaise
Post by papyblaise »
it is mandatory to support the sloping parts: the tail, the belly, the muzzle
bhs67
Post by bhs67 »
My apologies. I know this is not related directly to FreeCAD. I was hoping there was a good solution to the problem as I'm new to 3D printing.
I know that supports can be added. But that adds complications.
There are many stl files on Thingiverse that have portions of an object suspended in mid-air. Because this is common for many images, I thought that there may be a good way to handle this. Thanks for the responses.
BTW These are the types of images that grand-kids select.
Shalmeneser
cumbersome ... complications
Support is usually automatic in most slicers.
you could try splitting in half longitudinally, print sideways and then glue together, the legs would likely still require support though.
NHSA_Rainer
Post by NHSA_Rainer »
Moderators if this is OFF TOPIC please delete
This is not a forum for 3D Printing problem solutions as alreadyd said in previous posts.
There are very good facebook groups for 3D Printing in which you get help.
You could print your Dachshund like below. It prints in 1 hour 15 minutes with a layer height of 0.25mm at a speed of 25mm/s
Play in the slicer with the angle of support.
