forum usage: attachment upload 1.1 MB gives error
justwanttoknow
Post by justwanttoknow »
To have a better basis for discussion I try to upload a file.FCStd to a post, but it results on in:
Error
HTTP error.
Attachent appears in the attachment tab, but is not being posted.
Filesize is 1.1MB, while 1.46 is allowed..... tested zipped. Same result.
Any ideas? Thanks!
TheMarkster
Re: forum usage: attachment upload 1.1 MB gives error
Post by TheMarkster »
Where does it say 1.46? I'm not doubting you. I just can't find where it says that's the size limit. At the link below it says 1MB.
File attachments are limited to 1MB in size. If your *.FCStd file is too big to attach, you can use an online storage service (many are free like Google Drive, Microsoft OneDrive, Dropbox).
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
drmacro
Post by drmacro »
TheMarkster wrote: Fri Jun 24, 2022 5:07 pm Where does it say 1.46? I'm not doubting you. I just can't find where it says that's the size limit. At the link below it says 1MB.
Depends on the forum theme you use. I use prosilver and that is what is shown.
justwanttoknow
Here:
Screenshot from 2022-06-24 19-09-25.png (19.37 KiB) Viewed 638 times
No urgency as I've used a filehoster for the intended post. It might just be a bit misleading.
unfortunately that is the wrong size limit! the real size limit is 1mb, @yorik can this be corrected? this was also a source of confusion to me in the past.
I have fixed it. @drmacro, @adrianinsaval please check.
thanks, it's fixed
