New install of FreeCAD on Pop!OS (Ubuntu derivitive) Techdraw Vertices missing
BDL42
Post by BDL42 »
I taught myself FreeCAD just this year, and have been able to do some productive designs. Thanks for creating such a nice tool! Recently changed my linux distribution from Ubuntu 20.04 to Pop!OS 22.04, and have reinstalled FreeCAD on my laptop.
OS: Pop!_OS 22.04 LTS (pop:GNOME/pop)
Version: 0.19.
Python version: 3.10.2
Qt version: 5.15.2
OCC version: 7.5.1
The issue is vertices are no longer visible in TechDraw. They used to be visible on 20.04 Ubuntu. I had saved all my settings in .FreeCAD and .FreeCAD-temp. All of my old macros were preserved. If I run FreeCAD on Raspberry Pi OS 64 bit, I see vertices in my TechDraw drawing.
Can't dimension anything in TechDraw right now on Pop!OS, which, of course, reduces it's utility. I'm hoping it is some obscure setting of some sort. Under Preferences > Annotation I have Show Center Marks checked. Under TechDraw>Scale Vertex Scale = 3.00, Center Mark Scale = 0.50, which are the same as in RPI64 bit, which does show the vertices. Even if I delete the view and reimport the view, the vertices don't show up.
Part Design > Shape appearance Vertex size = 2 px.
I would be most grateful to be able to use TechDraw again. I use it to create drawings so I can machine parts in my shop. Hoping it is not unique to my drawing, but it is attached here. It is a model of a slotted square tube, which I will turn into a lathe tool rack.
tube.FCStd
(57.36 KiB) Downloaded 6 times
Re: New install of FreeCAD on Pop!OS (Ubuntu derivitive) Techdraw Vertices missing
Please retry with 0.20 and the AppImage.
BDL42
Post by BDL42 »
0.20 AppImage seems to work. The vertices show up again, with the same file.
0.19 did work on Ubuntu 20.04, and Raspberry Pi OS (64bit) without a problem. Wonder why it doesn't work on 0.19 on 22.04?
Can 0.20 AppImage run on an RPI4? I want to have the option to run on both platforms. Not that I want to be able to do designs on RPI4, but at least to view my designs. Recently went though laptop crashes and having an RPI4-8GB helped me get through the disaster unscathed.
How can I re-import my macros and some of my settings for use by the AppImage? Never used an AppImage before, so it is a new concept to me.
BDL42
Post by BDL42 »
Oh, I wasn't expecting a crash using an AppImage! I was trying to enable the Add On Manager and got a SIGSEGV.
~/Apps/freecadAppImage$ ./FreeCAD_0.20-29177-2022-06-15-conda-Linux-x86_64-py39.AppImage
FreeCAD 0.20, Libs: 0.20R29177 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
User path has changed to /home/bruce/.local/share/FreeCAD/. Please move user modules and macros
CEx::getCosmeticEdge - CE for tag: 2521b70b-9dfc-47be-b911-72355e5a2a43 not found.
CEx::getCosmeticEdge - CE for tag: 324da77b-8c4d-4570-b887-7d75c94aaae5 not found.
CEx::getCosmeticEdge - CE for tag: a64093be-9060-439a-b6e0-2ec92abc01f8 not found.
CEx::getCosmeticEdge - CE for tag: 64e4281b-aebf-4262-950a-e14d908c0a4c not found.
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f876d20a520]
#1  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x811bd2) [0x7f875257bbd2]
#2  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x21f37b1) [0x7f8753f5d7b1]
#3  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x22e55d8) [0x7f875404f5d8]
#4  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b34fcc) [0x7f875389efcc]
#5  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b3542e) [0x7f875389f42e]
#6  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b3569a) [0x7f875389f69a]
#7  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b357a5) [0x7f875389f7a5]
#8  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b30bfb) [0x7f875389abfb]
#9  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b30f25) [0x7f875389af25]
#10  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b31a2d) [0x7f875389ba2d]
#11  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b2a411) [0x7f8753894411]
#12  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b29524) [0x7f8753893524]
#13  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb3ff47) [0x7f87528a9f47]
#14  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb3ffb9) [0x7f87528a9fb9]
#15  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb41f87) [0x7f87528abf87]
#16  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb42447) [0x7f87528ac447]
#17  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb42552) [0x7f87528ac552]
#18  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b27f48) [0x7f8753891f48]
#19  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b24b4c) [0x7f875388eb4c]
#20  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1db0be0) [0x7f8753b1abe0]
#21  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd0f91) [0x7f8753b3af91]
#22  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd1caf) [0x7f8753b3bcaf]
#23  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd1e2d) [0x7f8753b3be2d]
#24  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e595a1) [0x7f8753bc35a1]
#25  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1df1f0f) [0x7f8753b5bf0f]
#26  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x19a2410) [0x7f875370c410]
#27  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e25018) [0x7f8753b8f018]
#28  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e55e6f) [0x7f8753bbfe6f]
#29  /lib/x86_64-linux-gnu/libc.so.6(+0x94b43) [0x7f876d25cb43]
#30  /lib/x86_64-linux-gnu/libc.so.6(+0x126a00) [0x7f876d2eea00]
#1  0x7f876c25a552 in Shiboken::BindingManager::retrieveWrapper(void const*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/./libshiboken2.cpython-39-x86_64-linux-gnu.so.5.13+0x12
#2  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/QtWidgets.cpython-39-x86_64-linux-gnu.so(+0x4f4b92) [0x7f8757b73b92]
#3  0x7f876d7844ef in QMetaObject::cast(QObject const*) const from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x17
#4  0x7f876e03cfb8 in QFusionStyle::polish(QWidget*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0x18
#5  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5(+0x1dc89a) [0x7f876e01189a]
#6  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5(+0x1dc177) [0x7f876e011177]
#7  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5(+0x1dc2b5) [0x7f876e0112b5]
#8  0x7f876f709a84 in Gui::MainWindow::showStatus(int, QString const&) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libFreeCADGui.so+0x214
#9  0x7f876f70b2a1 in Gui::MainWindow::customEvent(QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libFreeCADGui.so+0xb1
#10  0x7f876d796ff9 in QObject::event(QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x19f
#11  0x7f876dfd50af in QWidget::event(QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0xcc5
#12  0x7f876e07f385 in QMainWindow::event(QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0xdd
#13  0x7f876dfa9822 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0xdc
#14  0x7f876dfaf34d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0x1ac9
#15  0x7f876f2d3c49 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libFreeCADGui.so+0x89
#16  0x7f876d781f88 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x86
#17  0x7f876d7821c0 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x1da
#18  0x7f876d7aebc1 in QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x33
#19  /tmp/.mount_FreeCAEe0Jtz/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x59ef4) [0x7f87682f2ef4]
#20  0x7f876d77e99b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x187
#21  0x7f876e0ea90f in QDialog::exec() from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0x11d
#22  /tmp/.mount_FreeCAEe0Jtz/usr/lib/python3.9/site-packages/PySide2/QtWidgets.cpython-39-x86_64-linux-gnu.so(+0x25e513) [0x7f87578dd513]
#23  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libpython3.9.so.1.0(+0x13a1b7) [0x7f876ebed1b7]
#24  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libpython3.9.so.1.0(_PyEval_EvalFrameDefault+0x4b02) [0x7f876ebe58b2]
#25  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libpython3.9.so.1.0(+0x12d029) [0x7f876ebe0029]
#26  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libpython3.9.so.1.0(_PyFunction_Vectorcall+0xd5) [0x7f876ebee765]
#27  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libpython3.9.so.1.0(+0x145acd) [0x7f876ebf8acd]
#28  0x7f876c666be0 in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/./libpyside2.cpython-39-x86_64-linux-gnu.so.5.13+0xa0
#29  /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/./libpyside2.cpython-39-x86_64-linux-gnu.so.5.13(+0x1be16) [0x7f876c671e16]
#30  0x7f876d796f16 in QObject::event(QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0xbc
#31  0x7f876dfa9822 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0xdc
#32  0x7f876dfaf34d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Widgets.so.5+0x1ac9
#33  0x7f876f2d3c49 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libFreeCADGui.so+0x89
#34  0x7f876d781f88 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x86
#35  0x7f876d7821c0 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x1da
#36  0x7f876d7aebc1 in QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x33
#37  /tmp/.mount_FreeCAEe0Jtz/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x59ef4) [0x7f87682f2ef4]
#38  0x7f876d77e99b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0x187
#39  0x7f876d782811 in QCoreApplication::exec() from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libQt5Core.so.5+0xfd
#40  0x7f876f25875e in Gui::Application::runApplication() from /tmp/.mount_FreeCAEe0Jtz/usr/bin/../lib/libFreeCADGui.so+0x1b2e
#41  /tmp/.mount_FreeCAEe0Jtz/usr/bin/freecad(+0x67b1) [0x5643e42307b1]
#42  /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f876d1f1d90]
#43  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80) [0x7f876d1f1e40]
#44  /tmp/.mount_FreeCAEe0Jtz/usr/bin/freecad(+0x6af1) [0x5643e4230af1]
BDL42
Post by BDL42 »
More specifically, I selected the AddOn Manager, and checked the two boxes and clicked ok. Then the SIGSEGV happened. Guess I shouldn't do that!
Have used the AppImage again with no harm.
If the cross hairs are enabled for a hole, is there a way to turn them off? I only see a way to turn them on. Clicking again does not turn them off.
BDL42
Post by BDL42 »
Clicking help shouldn't cause a seg fault either... When I did that, it crashed. As a brand new user to this AppImage, this is not impressive.
Cloning repo...
Lock acquired...
Initial clone complete...
Checking out HEAD...
Clone complete
Cloning repo...
Lock acquired...
Clone complete
Optional dependency on pypandoc ignored because it is not in the allow-list
Noneb'pip 22.1.2 from /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/pip (python 3.9)\n'pip 22.1.2 from /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/pip (python 3.9)
Collecting markdown
  Downloading Markdown-3.3.7-py3-none-any.whl (97 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 97.8/97.8 kB 1.4 MB/s eta 0:00:00
Collecting importlib-metadata>=4.4
  Downloading importlib_metadata-4.11.4-py3-none-any.whl (18 kB)
Collecting zipp>=0.5
  Downloading zipp-3.8.0-py3-none-any.whl (5.4 kB)
Installing collected packages: zipp, importlib-metadata, markdown
Successfully installed importlib-metadata-4.11.4 markdown-3.3.7 zipp-3.8.0
Cloning repo...
Lock acquired...
Clone complete
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f190bb9b520]
#1  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x811bd2) [0x7f18f0cd4bd2]
#2  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x21f37b1) [0x7f18f26b67b1]
#3  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x22e55d8) [0x7f18f27a85d8]
#4  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b34fcc) [0x7f18f1ff7fcc]
#5  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b3542e) [0x7f18f1ff842e]
#6  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b3569a) [0x7f18f1ff869a]
#7  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b357a5) [0x7f18f1ff87a5]
#8  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b30bfb) [0x7f18f1ff3bfb]
#9  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b30f25) [0x7f18f1ff3f25]
#10  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b31a2d) [0x7f18f1ff4a2d]
#11  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b2a411) [0x7f18f1fed411]
#12  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b29524) [0x7f18f1fec524]
#13  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb3ff47) [0x7f18f1002f47]
#14  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb3ffb9) [0x7f18f1002fb9]
#15  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb41f87) [0x7f18f1004f87]
#16  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb42447) [0x7f18f1005447]
#17  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0xb42552) [0x7f18f1005552]
#18  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b27f48) [0x7f18f1feaf48]
#19  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1b24b4c) [0x7f18f1fe7b4c]
#20  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1db0be0) [0x7f18f2273be0]
#21  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd0f91) [0x7f18f2293f91]
#22  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd1caf) [0x7f18f2294caf]
#23  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1dd1e2d) [0x7f18f2294e2d]
#24  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e595a1) [0x7f18f231c5a1]
#25  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1df1f0f) [0x7f18f22b4f0f]
#26  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x19a2410) [0x7f18f1e65410]
#27  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e25018) [0x7f18f22e8018]
#28  /tmp/.mount_FreeCApdhIrU/usr/lib/python3.9/site-packages/PySide2/../../.././libQt5WebEngineCore.so.5(+0x1e55e6f) [0x7f18f2318e6f]
#29  /lib/x86_64-linux-gnu/libc.so.6(+0x94b43) [0x7f190bbedb43]
#30  /lib/x86_64-linux-gnu/libc.so.6(+0x126a00) [0x7f190bc7fa00]
I never had crashes like this using the distro versions. What's wrong? Thought I downloaded Stable.
BDL42 wrote: Fri Jun 24, 2022 9:19 pm If the cross hairs are enabled for a hole, is there a way to turn them off? I only see a way to turn them on. Clicking again does not turn them off.
What are you talking about? Which workbench? Example? Detailed description?
(Sorry, but I cannot help with the AppImage problems.)
BDL42
Post by BDL42 »
TechDraw workbench.
BDL42
Post by BDL42 »
There is a command to add circle centerlines in TechDraw. Is there a way to remove them?
chuckwrench.FCStd
(24.82 KiB) Downloaded 10 times
This simple drawing is to figure out the hole spacing for a pin spanner.
@chennes @looo @yorik any clues why this would be crashing? problem with qt webengine maybe?
