Drawing workbench active by default
drmacro
Post by drmacro »
Just talked to a new user who installed 0.20 and was confused that Drawing workbench is active by default. And when clicked, recommends using TechDraw.
To quote him:
"I'm just confused why is obsolete workbench enabled by default.
It's good to keep legacy tools for whatever reason
but have them disabled by default"
I would agree. :roll:
thomas-neemann
Re: Draft workbench active by default
Post by thomas-neemann »
drmacro wrote: Thu Jun 23, 2022 11:52 am ...
draft is included in arch. I think you could rename arch to arch-draft and disable draft
user1234
Post by user1234 »
drmacro wrote: Thu Jun 23, 2022 11:52 am Just talked to a new user who installed 0.20 and was confused that Draft workbench is active by default. And when clicked, recommends using TechDraw.
Draft is as far is i know not default. Also Draft is not obsolete, never was. Drawing is obsolete. But compiling without Drawing is not possible atm, since TechDraw seems to have still some functions from Drawing.
Drawing became obsolete in 0.17; consider using TechDraw instead.
Greetings
user1234
edit: typo
drmacro
Post by drmacro »
thomas-neemann wrote: Thu Jun 23, 2022 11:59 am
This, again, points to the blunderbuss approach of the install process and the discussions about the install guiding the user through selecting initial configurations...
drmacro
Post by drmacro »
drmacro wrote: Thu Jun 23, 2022 11:52 am Just talked to a new user who installed 0.20 and was confused that Drawing workbench is active by default. And when clicked, recommends using TechDraw.
To quote him:
drmacro
Post by drmacro »
user1234 wrote: Thu Jun 23, 2022 12:04 pm
Greetings
user1234
edit: typo
You are correct, I was referring to Drawing, not Draft. I'll edit the OP accordingly.
user1234 wrote: Thu Jun 23, 2022 12:04 pm But compiling without Drawing is not possible atm, since TechDraw seems to have still some functions from Drawing.
I regularly compile without drawing and use it without issues, I don't think techdraw depends on it since it is it's replacement, arch and draft had some dependencies on it which were recently replaced by corresponding techdraw functions, althought draft seems to have at least one remaining function to convert to/from? drawing objects.
@uwestoehr @yorik @wmayer should we consider not building drawing by default anymore? I feel like users of it were given enough time to migrate to techdraw already and to keep shipping it can be confusing to new users that might waste their time learning and using it instead of techdraw, at the very least it should be installed but disabled as drmacro suggests.
On that note, there is one test in draft wb that fails if you don't compile drawing wb, what to do about that?
user1234
Re: Drawing workbench active by default
Post by user1234 »
adrianinsaval wrote: Thu Jun 23, 2022 5:52 pm I regularly compile without drawing and use it without issues
Sorry, you are right. I made now a clean build without it and that works. Sorry for my bs i spread.
I think the flag for compiling with it as default can be removed in the master (and development/toponaming) branch. Have someone a drawing made with the drawing WB? It would be interesting, if it loads without the WB. If yes the source would be not necessary as well.
Greetings
user1234
adrianinsaval wrote:@uwestoehr @yorik @wmayer should we consider not building drawing by default anymore?
Yes, it should be disabled now.
Are you sure that Drawing isn't built any more? Although TechDraw doesn't use any Drawing function any more (since January I guess) there is still a link dependency: https://github.com/FreeCAD/FreeCAD/blob ... ts.txt#L39 However, this dependency can be simply removed without causing any linking errors.
OK this must be checked and fixed, then.
yorik
Post by yorik »
AFAICS Draft and Arch have all switched to corresponding TechDraw functionality. For me Drawing is safe to disable too.
