Measure Line colour and text size
vm4dim
Re: Measure Line colour and text size
Post by vm4dim »
adrianinsaval wrote: Thu Jun 23, 2022 7:20 pm but how to set those parameters? freecad's way of saving color parameters has always been weird
Tools > Edit Parameters
BaseApp > Preferences > View
Create Text Parameter: Dimensions3dColor, DimensionsDeltaColor or DimensionsAngularColor
Format: #RRGGBB
thanks it works, a lot of other color parameters on freecad unfortunately are saved as an "unsigned int" whatever that is and I don't what black magic ritual you have to perform to go from RGB values to that.
try vm4din's suggestion @NHSA_Rainer
Edit: documented this now in Fine-tuning
vm4dim
Post by vm4dim »
NHSA_Rainer wrote: Thu Jun 23, 2022 6:35 pm ... this is a so called hardcoded issue and well will have to live with it :(
Why hard? This is Open Source.
A little magic and Font/Size can also be changed.
vm4dim
Post by vm4dim »
[PartGui] Use Parameters for Measure labels font name and size #7088.
https://github.com/FreeCAD/FreeCAD/pull/7088
Parameters can be set in the Python console
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetString("DimensionsFontName", "FreeMono :Bold")
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetUnsigned("DimensionsFontSize", 36)
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetString("Dimensions3dColor",     "#FFFF00")
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetString("DimensionsDeltaColor",  "#FFFFFF")
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetString("DimensionsAngularColor","#0000FF")
FreeCADGui.runCommand('Part_Measure_Refresh',0)
NHSA_Rainer
Post by NHSA_Rainer »
Hi vm4dim, adrianinsaval et Al.
Thank you very much but please do not misunderstand me.
I am a 69 year old retiree (soon 70) and have 0 clue about programming and especially getting into the bowels of such a highly sophisticated program like FreeCAD.
Sorry for being dumb ... and not daring to destroy my running software.
Have a nice weekend.
Rainer
the color change does not require any programming at all! The interface to change is cumbersome though, perhaps they could be shown as option in the task widget.
NHSA_Rainer
adrianinsaval wrote: Fri Jun 24, 2022 11:43 pm the color change does not require any programming at all! The interface to change is cumbersome though, perhaps they could be shown as option in the task widget.
Thanks.
I have tried according to the instructions but do not advance much after opening Tools > Edit parameters ...
What makes me a bit dizzy is the following
" Create Text Parameter: Dimensions3dColor, DimensionsDeltaColor or DimensionsAngularColor "
and especially the word " or " ...
Hw do I know what to add in that sentence. Is the or applying to the whole sentence or does it mean I have to create 3 new lines
consiting how ?
and where would this new setting appear ?
A big help would be to show me an example of how it is created via screenshots.
Thanks Rainer
Roy_043
Post by Roy_043 »
NHSA_Rainer
Roy_043 wrote: Sat Jun 25, 2022 8:35 am Have you read Std_DlgParameter#New_string_item?
I just read it, not once but a few times, but still full of questions about how to implement it, define a colour via a text string and where will I see the added result or will this just in hidden way change the parameters of the measure lines ?
Sorry for not understanding this.
Rainer
vm4dim
Post by vm4dim »
NHSA_Rainer wrote: Sun Jun 26, 2022 7:38 pm where will I see the added result or will this just in hidden way change the parameters of the measure lines ?
Push https://wiki.freecadweb.org/Part_Measure_Refresh
