[SOLVED:] Sketches get moved to another plane
fr33cadtom
Post by fr33cadtom »
Here is my current version info:
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
I have an issue where I have a sketch built on a face and when I reopen the file it ends up on another plane. I have tried to attach it to the correct face or to the xy plane, but then freecad hangs.
In the attached file it is the sketch called hubsketch.
I have had this issue with other files as well.
Any help would be appreciated.
thanks,
Tom
Ellen lamp gear-lg.FCStd
(738.89 KiB) Downloaded 24 times
bambuko
Re: Sketches get moved to another plane
Post by bambuko »
When I open your file in Master branch, I get following error messages:
07:45:45  <string>(1)<class 'ModuleNotFoundError'>: No module named 'freecad.gears'
07:45:45  <string>(1)<class 'ModuleNotFoundError'>: No module named 'pygears'
I guess it is because I have no Gear workbench installed?
I am having difficulty getting it going in Master branch
so I opened it in Linkstage3 branch and...
Your sketch is attached to "fillet face"
Bad practice on many levels....
fillet face.png (35.26 KiB) Viewed 2084 times
use Attachment editor to correct attachment mode:
In this case I used XY plane.
Good practice.
You can further offset the attachment to get it to the right place:
And the resulting model:
Screenshot from 2022-06-21 06.51.32.png (101.49 KiB) Viewed 2084 times
I didn't check anything else in the file - there may be other. similar problems...
modified file:
Ellen(bambuko).FCStd
(550.34 KiB) Downloaded 16 times
I have used:
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 0.21.29229 (Git) Snap 78
Hash: 9db32a391142d9dbaf9e2d94c857a2a099e9d905
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
  * DynamicData 2.46.0
  * ToolViewReverse_ToolBar
  * sheetmetal 0.2.49
  * Manipulator 1.4.3
  * Assembly3 0.11.3
  * fasteners 0.3.40
  * ThreadProfile 1.81.0
fr33cadtom wrote: Mon Jun 20, 2022 9:45 pm I have tried to attach it to the correct face or to the xy plane, but then freecad hangs.
You should retry with the now stable 0.20 version.
bambuko
Post by bambuko »
I continued playing with it, and what solved it for me was deleting all the fillets, before re-attaching hubsketch to correct plane.
One of the fillets was corrupted with wrong edge and since your sketch was attached to the fillet :roll: :twisted: ;)
it was messing things up (and yes FreeCAD was hanging up as you have described)
Ellen(bambuko2).FCStd
(324.73 KiB) Downloaded 11 times
File above is without fillets.
You can always add fillets as a last operation :)
What puzzles me is why it was so easy to solve it in Link branch and such a pain in Master branch :ugeek: but that's another story
drmacro
Post by drmacro »
bambuko wrote: Tue Jun 21, 2022 7:09 am ...
I'm not sure what you mean here. I don't find fixing disenfranchised attachment difficult in master.
That is why I don't bother with linkstage3... 8-)
bambuko
Post by bambuko »
drmacro wrote: Tue Jun 21, 2022 10:14 am ...I'm not sure what you mean here....
It wasn't criticism, just curiosity about the differences.
It is possibly to do with TPN differences?
i.e. in Master everything was crashing when I edited attachment (as described by OP) until I deleted offending fillets.
whereas in Link I just changed attachment and all was hunky-dory.
Not going to loose sleep over it :mrgreen:
I know what I like ;) (and so do you, I guess :lol: )
drmacro
Post by drmacro »
bambuko wrote: Tue Jun 21, 2022 10:37 am
My typical workflow in cases like this is to immediately set skip recomputes, then set the tip to the highest non-error feature and work my way down.
Fillets are of course a bugger, since, by nature they depend on generated geometry.
fr33cadtom
All,
thank you for the suggestions and help. I have upgraded to version 0.20. I then deleted the fillets. When I originally created the hub sketch, I attached it to the face of the gear before I added the ring pad. I have no idea how it ended up being supported by the fillet but can see how that would be very bad.
I was able to support it on XY_Plane001. If I wanted to support it on the face of the gear, how would I do that? I tried several things but was unsuccessful.
Thanks again.
Tom
drmacro
Post by drmacro »
fr33cadtom wrote: Tue Jun 21, 2022 10:43 pm All,
Thanks again.
Tom
Attaching to the face of the gear is not a good idea. That would be attaching to generated geometry and is like to result in what is called TNP. (Topological Namimg Problem).
Which is quite likely what caused the issues to begin with. There were/are other sketches attached to generated geometry in the file I looked at.
bambuko
Post by bambuko »
drmacro wrote: Tue Jun 21, 2022 2:15 pm .. then set the tip to the highest non-error feature and work my way down.
That's a good tip :lol: (pardon the feeble pun)
I didn't think about it - probably because I practically never experience TPN TNP (it's so easy to avoid it ;) )
so have little practice in recovering from the mess created by it...
