FreeCAD v0.20 and importing Inventor .IPT files
mp77Bushnell
Post by mp77Bushnell »
Version: 0.20.28968 (Git)
Hash: 03f38526172d8bc6274ddfb5cdd3ad6b691f5f56
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, OCC 7.6.2
  * A2plus
  * dxf-library
  * InventorLoader 1.3.0
  * InventorLoader-master
I installed Beta .20 tonight
I installed Inventor mods
(see above)
I then tried.. to import an inventor 2019 IPT file
FAILED.
See below which is I hope are the error messages
22:17:30 Traceback (most recent call last):
File "C:\Program Files\FreeCAD 0.20\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "C:\Users\gandrews\AppData\Roaming\FreeCAD\Mod\InventorLoader-master\importerIL.py", line 8, in <module>
import os, sys, FreeCAD, importerSAT, Import_IPT
File "C:\Users\gandrews\AppData\Roaming\FreeCAD\Mod\InventorLoader-master\importerSAT.py", line 8, in <module>
import tokenize, sys, FreeCAD, Part, re, Acis, traceback, datetime, ImportGui
File "C:\Users\gandrews\AppData\Roaming\FreeCAD\Mod\InventorLoader-master\Acis.py", line 10, in <module>
from importerUtils import *
File "C:\Users\gandrews\AppData\Roaming\FreeCAD\Mod\InventorLoader-master\importerUtils.py", line 14, in <module>
from olefile import OleFileIO
<class 'ModuleNotFoundError'>: No module named 'olefile'
I have looked at other IPT posts (seems I’m not alone)
I looked for Youtubes (one previously mentioned seemed to point at grabcad not free cad and another said to change extension which was confusing.
So can anyone describe step by step how to inport an Inventor 2019 IPT file successfully and maybe tell me how to interpret the error messages above?
I hoped .20 would solve my issues but… so far I’ve had no luck.
Reason: fixed thread formatting and typo in title
thomas-neemann
Re: .20 aqnd importing Inventor .IPT files
Post by thomas-neemann »
mp77Bushnell wrote: Thu Jun 16, 2022 2:31 am ...
Can you upload the file somewhere?
mp77Bushnell
Seems "attachments" rejects .IPT files so
I am attaching with changed name and extension... HOPEFULLY this WORKS<G>
It WAS .ipt
Now it is .txt
Hopefully changing it and changing it back on you end does not break it.
ONE BLOODY WINDOW KNIGHT.txt
(91 KiB) Downloaded 19 times
thomas-neemann
mp77Bushnell wrote: Fri Jun 17, 2022 6:59 pm ...
here it works
Version: 0.20.29177 (Git) AppImage
  * Assembly3 0.11.3
mp77Bushnell
So does that suggest it work in Ubuntu 20.04 and NOT in Windows?
Could it be the add on and OS?
Since I'm having difficulties with what should be "easy"... getting into differences between OS releases is WAY BEYOND MY PAY GRADE!
Anyone have success in Windows?
or looked at the errors I was getting?
Thanks.
Gordon
mp77Bushnell
Re: .20 and importing Inventor .IPT files
Thanks.
Gordon
Roy_043
Post by Roy_043 »
I encounter no issue importing the IPT file. Note that I do not have an InventorLoader-master folder. I suggest you move that folder to a temporary location where FreeCAD can't find it, reinstall InventorLoader, restart FreeCAD, and try again.
Branch: releases/FreeCAD-0-20
  * sheetmetal 0.2.49
unrelated but why install beta when the stable release is already available? https://github.com/FreeCAD/FreeCAD/releases/tag/0.20
