Hi all.
Trying to look for info how rotation calculates here with (x,y,z,A - options in Orientation).
What i need:
i have body, that i need to rotate depends on 3 angles in spreadsheet (YAW(X,Z,bodyaxisX in scene))
Example:
is Spreadsheet:
| Y | A | W |
| 0 |90 | 45|
| result: |
| x | calculated |
| y | calculated |
| z | calculated |
| A | calculated |
next cells will be used in body orientation for calculated values.
What i search:
How current calculation works? and how i can recalculate?
ps. tryin to search euler angles calculations, but can't figure out what kind of calculation used here. or may be someone show me what source file makes calculations in freecad.
pps, i don't need using menu or manualy write x,y,z,A or rotate using other drawing tools, because i need flexible calculation
Orientation with Spreadsheet
Re: Orientation with Spreadsheet
Hi and welcome to the forum!
See Expressions on calculation possibilities
If it is not done automatically, click the Recompute icon.and how i can recalculate?
Hi, i know how spreedsheet works. i need calculation of rotation. in short, i have rotation scheme like ZYZ, or XZX with known angels, like (90,45,90) in YZY, i set those angles in spreedsheet and need to translate it into (Angle, axises(x,y,z))-form that i will use in body->Placement. how i can calculate this (Angle,x,y,z) matrix. i can't understand how FreeCad calculates Body position from them and how i can calculate from ZYZ(for example) into (A,x,y,z) form (it manualy able to do from Edit->Placement step by step, but i need to do this in spreedsheet).
also if i have current(A.x,y,z) - i need to recalculate it for ZYZ(for example) rotation with (90,45,90)angles (as example) and get new values for (A,x,y,z)
It's not clear what it is you don't know how to do. Spreadsheets support the creation of rotations and placements. They support the compounding of rotations eg rot = rot_yaw * rot_pitch * rot_roll
Here's a file with a spreadsheet, placing cubes with the same rotation computed directly or from yaw, pitch, roll separately.
https://wiki.freecadweb.org/Expressions#Create_function
https://wiki.freecadweb.org/Sandbox:Edw ... ler_Angles
- spreadsheetrotations.FCStd
- (6.18 KiB) Downloaded 9 times
strange file for me. i see functions, but do not see how it sets coordinates of cube. on cube properties-> placement Angle and axis do not linked to spreedsheet's cells and no macros there. in functions i do not see linkage with any cube. how it sets cube's placement data?
Right click on the Placement property and select Expressions. It shows the linkage to the spreadsheet alias.
EDIT: You may want to pay attention to right click|show all in Properties - which shows stuff that is not normally useful to the casual user.
thanks, now i see.
for now i think this is best way to set rotations.
